Mini mic that can plug directly into an XLR mic preamp without cable?
Post by dickiefunk »
Are there any mini mics that can plug directly into the xlr socket of a mic preamp without a cable? I'm thinking of something similar to the old AKG D58E.
The mic will be used for talkback duties and I would prefer not to use a gooseneck type mic.
dickiefunk
Posts: 2099 Joined: Fri Jun 17, 2005 12:00 am Location: Cornwall, UK
Re: Mini mic that can plug directly into an XLR mic preamp without cable?
Canford Audio's Stub mics?
https://www.canford.co.uk/CANFORD-STUB-MICROPHONES
Dynamic cardioid mics, in black or silver.
Posts: 43706 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
There were some mini mics built into an XLR connector - although they often needed phantom power which isn't always available from a talkback connector.
https://naiant.com/custom_audio_reprodu ... ification/
is the sort of thing I'm thinking of.
Posts: 16993 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
If there is phantom power you could get a pair of Behringer C2s (very wee) and two XLR couplers for about a nifty.
Posts: 19149 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Posts: 22918 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Went out of business at least 7 years ago.
Posts: 19211 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Post by forumuser840717 »
D58Es aren't too hard to find secondhand. And generally aren't particularly expensive.
Harder to find but just as good (if not better) is the Beyerdynamic equivalent - the M424N(C)
There are also several full sized Beyers and AKGs which, in some versions, will fit directly into panel XLRs.
And there are quite a lot of "comms" mics from the likes of AKG, AT, Beyer, Canford, DPA, Schoeps, Shure, and others, which have captive goosenecks of various lengths, e.g Beyer M640, which terminate in XLRs to plug into panel sockets. They can be quite handy when one wants to aim a panel mounted mic or just doesn't want to have to get nose to nose with a panel to make a noise cancelling talkback mic work properly.
At the more luxury end, a Neumann KM100 body will plug directly into a panel XLR.
forumuser840717
Posts: 485 Joined: Thu Jun 16, 2016 5:20 pm
Post by Bob Bickerton »
Lots of options here: https://immersivesoundscapes.com/
I have a couple of omnis and they’re fine.
Bob Bickerton
Posts: 5642 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Thanks for all the recommendations! The Canford mic looks like it would would fine.
I haven't heard of Immersive Soundscapes and I'm interested in finding out more about these. Where are they located?
dickiefunk
Based in France. Apparently there’s a few brands making similar models, mostly used for outdoor ambient recordings. Not a nice as MKH 8020s, but then they wouldn’t would they ;)
Bob Bickerton
Thanks Bob. I'd be interested to know who else is making similar mics.
dickiefunk
