forumuser844936 wrote: ↑Fri Feb 14, 2025 6:01 pmSecretSam wrote: ↑Wed Jan 08, 2025 6:14 pm If you want to leave space for the sounds to develop, or if you want to avoid your arrangement turning to mush under the weight of filters, distortion, modulation, delays and discarded pizza boxes ... or whatever... it might be a smart choice to simplify the harmony and thin out the chords.
Thin out the sounds not the chords , you're thinking like an amateur who prioritizes mixing and production! Ironically, reading too much web forums will lead you there ...
Probably best to explain by example:
Have a look at a jazz real book, and pick a tune that uses harmonic minor modes, where you usually have to voice stuff like 7th chords with a flat 9 and a sharp 5, and where the chords change every two to eight beats. There will plenty to choose from. Set up your keyboard with lots of distortion, delay, reverb and phasing.
It will be an interesting special effect, but you won't get much musical or textural information out of it because there's too much going on. You might be an exception, but I suspect most players would simplify the harmony or sharpen the sounds.
Or more simply: folk guitarists can get away with strumming six-string chords. Folks playing distorted electric guitars, on the other hand, tend to use thinner chords: two, three or four notes.
