It also happens with the vocal doubler on both the right and left panning. I’ve checked these plugins on sends, tested them individually, meaning I had only the autotune or only the vocal doubler in the FX chain. I’ve checked the sample rate, tried different microphones, different interfaces, and even bought a new Mac Mini M4 512GB, but the problem still occurs on this new hardware. I wouldn't blame it on the GPU; an important thing to note is that it also happens with acapella tracks from the internet or with other people's vocals from other computers.
Below, I’ll attach samples on Google Drive so you can hear what it sounds like.
I would really appreciate help because I honestly don’t know what to do. I’m recording rap vocals, my own.
My setup is: RODE NT1-A, AUDIENT ID4 MK2, ATH-M50x headphones.
it’s definitely not any phasing or anything like that because it’s abnormal to have strange distortion in one of the headphones while using Auto-Tune, or to have weird artifacts in the vocals when there are pitch/tonal changes in Auto-Tune (the closer to the Note Transition 0.1, the more artifacts appear). Speed 0.1 or 8.0 doesn’t change it, but the note transition does. It's not normal as most people would think that more extreme settings cause more artifacts, because my friend has exactly the same plugin, the same microphone, and doesn’t experience any of the artifacts I’m getting! For example, I’m using AutoTune Waves Real-time and Vocal Doubler by iZotope.
These are legal plugins, not cracked ones. I’ve also seen theories suggesting issues with cracked plugins, but these are compatible with my system (Sequoia 15.3).
I really don’t know what to do – I’ve checked different XLR cables, thinking it might be the microphone, switched microphones, and still, it’s happening. I also tried a different interface – still the same! I really don’t know what to do, please help.
(better listen in headphones, but you will catch it 100% even without)
EXAMPLE ON VOCAL DOUBLER:
CLEAR VOCAL WITHOUT VOCAL DOUBLER : https://drive.google.com/file/d/1k66NWp ... sp=sharing
VOCAL ISSUE (better listen in headphones, but you will catch it 100% even without) : https://drive.google.com/file/d/1jfnBX3 ... sp=sharing
EXAMPLE ON AUTOTUNE:
https://drive.google.com/file/d/1GsZ1wp ... sp=sharing
"I've added a few more screenshots below – maybe this will help someone find the issue. Thank you from the bottom of my heart
https:*?*?*/SDJMT2Qq
https:*?*?*/CsmMRTt7
https:*?*?*/9Hx4Z4Fr
https:*?*?*/XrRXnHw7
Edited to display images correctly. - Andy
