ManFromGlass wrote: ↑Fri Mar 28, 2025 1:26 pm
I have been doing some testing of a number of interfaces that I have.
Okay... what software are you using to do this testing, and how are the interfaces connected/configured?
I am bewildered by the noise a number of EQs from different companies have been showing me.
I'm confused! Are you testing hardware EQs via your interfaces? Or are you using the FFT analysers in EQ plugins to provide a very dodgy form of noise measurement?
I test the interfaces with nothing plugged into them, in or out.
Not a good idea! Unterminated inputs can pick up interference and generate a lot of noise. It's better to use a 'shorting plug' or a representative source impedance to provide a meaningful noise floor.
Should I be concerned?
I wouldn't be. The EQ fft is not a calibrated measurement tool. It probably has an auto gain-ranging function which will raise the noisefloor to ensure the frequency components are visible, and it will lack the required averaging across multiple scans needed to properly assess the noisefloor.
...and the reason those EQ plots slope upwards is because they're designed to give a flat response to pink noise (and music), rather than the white noise generated by electronics!
If you want to know what your interface A/D noise floor is, use a shorting plug, and record a 10 second track then use digital gain in the DAW to pull the noisefloor up to something that you can read on the meters (-20dBFS etc). Then subtract that amount of added gain from the meter reading to get a reasonable idea of the noise floor figure.
