Hello everyone,
A simple question - my audio interface (Scarlett 18i8 3rd gen.) is situated approximately 4 meters from my computer (standard MacBook Pro). Is it safe to use a 5 meter USB-C to USB-A cable? (Or do I need to reorganize my studio...?) Or maybe an active USB repeater is OK?
By the way, Focusrite's recommendation is "maximum 2 meters".
Thank you in advance for your comments!
Best regards from Sweden,
Per Andersson
Length of USB cable
Length of USB cable
- Per Andersson
New here - Posts: 7 Joined: Tue Aug 25, 2020 10:09 pm
Re: Length of USB cable
USB 1.1 and USB2.0 will work happily with cable up to 5 metres, which should be cope with the majority of multi-channel audio interface, but if this is a USB 3.0 and 3.1 device only recommend cables up to 3 metres in length.
Focusrite's Scarlett 18i8 3rd gen claims to be a USB 2.0 device, so despite their recommendation of 3-metres I'm pretty sure you'll be fine with 5-metres.
Many thanks!
/ Per
/ Per
- Per Andersson
My experience with a Native Instruments KA6, two different brands of 5m cable and two tower computers was, shall we say, odd?
One PC would not work with one USB cable but the other PC was fine with both.
NI stated the maximum length as 3m and they supplied a good quality 3m cable.
Do note that the KA6 is powered wholly via the cable whereas the Focusrite has a 12V supply. I doubt there is much resistive loss over a 5m cable but there might just be enough to matter in some cases. Buy the best quality cable you can find. "Lindy" are I think a good brand?
https://www.lindy.co.uk/cables-adapters ... ine-p11296
Hardly going to kill your flexible friend to try!
Thank you for you comments!
Best regards,
Per
Best regards,
Per
- Per Andersson
I've used the active USB cables daisy chained up to 15m to connect a laptop to my XR18 without any problems.
Regards, Simon.
Regards, Simon.
- Stratman57
Frequent Poster - Posts: 640 Joined: Wed Apr 20, 2005 12:00 am
Stratman57
ef37a wrote: ↑Wed Apr 16, 2025 11:59 pm My experience with a Native Instruments KA6, two different brands of 5m cable and two tower computers was, shall we say, odd?
Yes, I should have stated a high quality 5 metre USB cable, as there are certainly some dodgy ones about that misbehave when asked to work close to their claimed limits.
Lindy cables are indeed regularly recommended on the SOS Forums, yet are still very reasonably priced.
Stratman57 wrote: ↑Thu Apr 17, 2025 9:21 am I've used the active USB cables daisy chained up to 15m to connect a laptop to my XR18 without any problems.
Regards, Simon.
Good to know Simon. I have not tried any active USB extension but would add a note of caution? Audio Interfaces can be fussy b'stds. What works for one may not work for another. If you buy such a cable make sure you can return it in case of problems.
Maybe the top blokes here could suggest ways to max out the AI/cable/PC system to prove things out?
I have demos in Adobe Audition 1.5 and Samplitude Pro X 6. I reckon they give a good workout?
