Test rig
Test rig
https://www.elektor.com/products/fnirsi ... tW8.QQ33pb
Looks very good for the money? I am sorely tempted but really have no use for such a thing except to "play" with and that is three months and bit petrol.
Re: Test rig
It does look like good value Dave, especially if you need coverage up to 10MHz, although for basic audio purposes I still use the freeware Visual Analyser PC software utility for my oscilloscope and spectrum analyser requirements:
https://www.sillanumsoft.org/prod01.htm
It does everything I need to do, and with very professional results!
Re: Test rig
Reaper users have a reasonably good oscilloscope built in. I'm tempted by something like a Picoscope which aren't much more expensive than the one Dave linked to if you go for the basic model. Space is at a bit of a premium here and my conventional scope just takes up too much of it.
Posts: 16988 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Re: Test rig
James Perrett wrote: Tue Apr 29, 2025 4:22 pm Reaper users have a reasonably good oscilloscope built in. I'm tempted by something like a Picoscope which aren't much more expensive than the one Dave linked to if you go for the basic model. Space is at a bit of a premium here and my conventional scope just takes up too much of it.
I don't know what it's like now, but I tried picoscope a few years back and was somewhat underwhelmed. It's only 8 bit resolution too.
Re: Test rig
Depends what you're trying to measure, but I use a 2000-series Picoscope (which is 8 bit) and have no problems with it at all for analogue and digital audio work. And its far more powerful and capable than the two-channel CRT telequipment scope I inherited from a BBC skip.
Posts: 43690 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Re: Test rig
Folderol wrote: Tue Apr 29, 2025 5:07 pm I don't know what it's like now, but I tried picoscope a few years back and was somewhat underwhelmed. It's only 8 bit resolution too.
I was surprised to find just how many digital scopes from respected brands are 8 bits. The Keysight scopes that I used at work looked noticeably better than the cheap Rigol scope that someone else bought but the paper specs were remarkably similar.
Re: Test rig
Do we! and where is it? and here's me just about to go and buy something.
Re: Test rig
Post by Nazard »
Rigol and Siglent are moving or have moved all their current DSOs to 12 bit.
Nazard
Re: Test rig
Nazard wrote: Wed Apr 30, 2025 8:09 am
That was done several years ago, and the difference is quite dramatic - without using any interpolation (i.e. smudging).
Re: Test rig
Folderol wrote: Wed Apr 30, 2025 8:21 am
Nazard wrote: Wed Apr 30, 2025 8:09 am Rigol and Siglent are moving or have moved all their current DSOs to 12 bit.
Have you directly compared them to something like an 8 bit Keysight 'scope? To use an old computing analogy - the 8 bit Rigol scope that I used felt like the equivalent of using an old CGA display when I was used to using something like SVGA with the Keysight.
Re: Test rig
James Perrett wrote: Wed Apr 30, 2025 9:28 am
No. I've only seen a small subset of digital scopes.
It does of course depend on what you are using them for. For a lot of audio purposes I suppose they are adequate, although I'd always find the pixelation a bit annoying. However, if using them for design work it's a different story. The classic one being testing crossover point on class B amps. I've seen cases where at certain settings you can get a very narrow burst of parasitics which would show up clearly on a 10M analog scope, but be quite invisible on a digital one.
Re: Test rig
Arpangel wrote: Wed Apr 30, 2025 7:35 am
I didn't know either, but I've just found the JS: Oscilloscope Meter plugin
Seems a bit basic though, unless I've missed some controls.
Having said that, I've just also discovered the JS: Bit Meter, which gives a clearer visual display than the one I'm currently using.
Re: Test rig
Martin Walker wrote: Wed Apr 30, 2025 10:34 am
Check the blue buttons at the top. You get triggering on positive edges or falling edges, variable sensitivity, variable timebase and single shot. If you would like more then, being a JS effect, you can always add extra features yourself.
Re: Test rig
James Perrett wrote: Wed Apr 30, 2025 11:02 am Check the blue buttons at the top. You get triggering on positive edges or falling edges, variable sensitivity, variable timebase and single shot. If you would like more then, being a JS effect, you can always add extra features yourself.
Yes, I found those, but have spent a lot of time over the years examining the effect of a host of preamp plugins on drum transients, so I'd have to improve the JS triggering options - I found it difficult to get a stable one-shot trace with anything other than simple signals (e.g. a Dirac pulse locked beautifully, but most single drum hits didn't).
Re: Test rig
Post by nathanscribe »
Prices on 12-bit scopes have come down now though, the days of the 1054z being the go-to budget unit are numbered! The recent budget 12-bits are very attractive.
nathanscribe
Posts: 1566 Joined: Fri Jan 19, 2007 12:00 am Location: Wakefield, for my sins.
Re: Test rig
This Reaper scope is a godsend, all I need it for is for checking synth waveforms, it does that perfectly well.
Re: Test rig
nathanscribe wrote: Wed Apr 30, 2025 2:58 pm
Yes I expect they are, but I'm very much out of the loop these days. I've not even fired up my analog scope for quite a few years now :(
Re: Test rig
I wish, I wish, I wish... that I knew how to use one of those things!! :headbang::lol:
Re: Test rig
The Elf wrote: Fri May 02, 2025 9:23 am I wish, I wish, I wish... that I knew how to use one of those things!! :headbang::lol:
They are one of the rare pieces of kit that can easily be understood (and used) for basic checks, and as you get familiar you can gradually expand your knowledge - at your own pace - until you reach whatever lever of expertise you need.
Modern all-singing-all-dancing ones can provide an enormous amount of highly detailed information.
Re: Test rig
Folderol wrote: Fri May 02, 2025 3:10 pm
+1 to this - once you can adjust triggering to get a stable image on the screen rather than a continuously horizontal scrolling waveform, you can zoom in and out to spot more or less detail.
Re: Test rig
I don't even have a starting point for what it does, or what I'd do with it. But I suspect that if I did I would have managed to salvage a few more of the broken offerings I take in. :lol:
Re: Test rig
I'd kind of like one, just for fun, but I have absolutely no use for it and a very limited toy budget! :D
Re: Test rig
The Elf wrote: Fri May 02, 2025 9:14 pm I don't even have a starting point for what it does, or what I'd do with it. But I suspect that if I did I would have managed to salvage a few more of the broken offerings I take in. :lol:
You know the waveform view on your DAW or audio editor? Well that's pretty much an oscilloscope trace.
A standard, old fashioned scope just shows you a small section of waveform in real time while a digital storage scope effectively gives you similar functions to a basic audio editor. You can record a waveform and then scroll and zoom in to the area of interest.
A good digital scope has a much higher sampling rate than a normal audio interface so you can see signals of at least a few MHz and often up to 100MHz or more. Analogue scopes are limited by the bandwidth of their Y amplifiers but they tend to have similar bandwidths to their digital brethren.
Re: Test rig
Drew Stephenson wrote: Fri May 02, 2025 10:04 pm I'd kind of like one, just for fun, but I have absolutely no use for it and a very limited toy budget! :D
I have an old analogue 'scope and, very occasionally, use it for it's intended purpose. But, mostly, it's a cool toy sat on a shelf in the workshop. I can't remember what I paid for it but it wasn't much (but I'll bet it was more than I paid for my Boxford lathe* but less than I paid for the lathe tooling).
* Which was free but lacked a few bits to allow it to become a fully functioning workshop machine.
Re: Test rig
The Korg NTS2 is a useful little oscilloscope, tweaked for ease of use in the audio world, and a fun easy assembly project.
https://www.soundonsound.com/reviews/korg-nutekt-nts-2
It's around £150, which might push the toy budget, but its a sweet thing that works well.
