Audio interface Question
Post by Pauliet »
I have a small mixer and want to send audio from the mixer to my DAW software. Obviously i need an audio interface (ADC & DAC) to accomplish this.
All the devices I see advertised have microphone / instrument inputs with level controls along with line inputs and line outputs.
Does anyone make an audio interface that is strictly line in and out?
Thanks for your suggestions.
Regards,
Paul
Pauliet
Posts: 3 Joined: Wed Apr 09, 2025 6:51 pm
Re: Audio interface Question
Post by Chet Leeway »
Check out MOTU's new 16A: It's got 16 in, 16 out, all line. Can be expanded with optical I/O.
Chet Leeway
Posts: 163 Joined: Fri May 06, 2016 8:13 pm Location: Barcelona
Post by Music Wolf »
A couple of questions.....
1) How many input and outputs do you require?
2) What is your budget?
Music Wolf
Posts: 2894 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
Mic inputs come as standard on most budget/mid price interfaces, you may just have to go along with them.
Interface questions? there seem to be a lot lately, maybe we should start a seperate sub-forum!
Posts: 21952 Joined: Sat Jul 12, 2003 12:00 am
Arpangel wrote: Wed Apr 30, 2025 7:57 am Mic inputs come as standard on most budget/mid price interfaces, you may just have to go along with them.
Yes, like the chap on another thread with his PCI card, this is where PC audio has gone. The vast majority of interfaces are USB and come with mic pres.
You all won't be surprised when I suggest Paul has a look at the MOTU M4?
That Paul has two rear line inputs for your mixer but also two more mic/line/instru inputs on the front. You don't say what your mixer is but I bet the M4 pres are quieter!
Also, at the risk of thrown rocks, for modest quality PC dubbing the Behringer UCA 202 is very useful. I am thinking recording podcasts? The quality beats cassette/vinyl hands down.
Another sub forum Arp'?! You will not be popular! There was a "choosing an audio interface" article not that long ago?
In think an interface sits pretty squarely in the 'recording gear' category. ;)
I’ll second the M4, a solid choice.
Pauliet wrote: Wed Apr 30, 2025 1:21 am All the devices I see advertised have microphone / instrument inputs with level controls along with line inputs and line outputs.
That's because they are relatively cheap to implement compared to the price that can be charged.
In my experience the Behringer UCA type interfaces are just too limited unless you just want something to digitise a few cassettes or to add a basic audio output to something that doesn't already have an audio output.
I'd suggest the Behringer UMC202 is probably the cheapest you should be looking at.
Depending on your current needs and choice of interface you might be able to ditch the mixer entirely, which is worth considering to potentially simplify and shorten the recording chain.
Posts: 21436 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
The Elf wrote: Wed Apr 30, 2025 10:12 am Depending on your current needs and choice of interface you might be able to ditch the mixer entirely, which is worth considering to potentially simplify and shorten the recording chain.
+1 on this approach - when I abandoned my mixer many years ago I was frankly amazed at how much cleaner my recordings were made directly into my audio interface at the time.
Posts: 22580 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by ken long »
Chet Leeway wrote: Wed Apr 30, 2025 6:54 am Check out MOTU's new 16A: It's got 16 in, 16 out, all line. Can be expanded with optical I/O.
Hey this is great! Price is decent too.
ken long
Posts: 3631 Joined: Mon Jan 21, 2008 12:00 am Location: Somers Town
I'm All Ears.
ken long wrote: Wed Apr 30, 2025 2:43 pm
Yes, not a bad price IF you already have some mic pres (or a mixer!).
I did think that M6 would have been better with ADAT?
Post by ken long »
It's great if you have a line only setup and happy mixing ITB!
ken long
I'm All Ears.
Post by Pauliet »
Thanks for all your inputs.
The mixer is from Tascam and has four outputs. I typically use two outputs for monitors and the other two to record stereo. I wanted to simply connect two line outputs to an ADC and connect to a computer. That's why I was looking for a simple device with only a couple of line inputs.
Guess it time to throw it out and start over!
Pauliet
Post by forumuser931182 »
What about ESI U24 XL 24-bit USB Audio Interface for PC and Mac with S/PDIF I/O
forumuser931182
Posts: 204 Joined: Fri Jul 08, 2016 4:23 am Location: Australia
Post by NéstorRC »
You actually don’t need a fancy “line‑only” box, most interfaces let you hit a switch or trim a preamp all the way down so it’s just passing line level. If you really want dedicated line ins and outs, look at units like the MOTU 828es or Focusrite Clarett which let you disable their mic pres and run straight line signals. On the budget side, you can grab a simple USB box with RCA I/O and skip the XLR pres altogether.
NéstorRC
Posts: 2 Joined: Fri Mar 07, 2025 9:39 am Location: Spain
Néstor Rausell
www.masteringbox.com
