Hartke HA2500 Bass Amp
Post by GRAHAM99 »
I have acquired a Hartke HA2500 bass amp.
It sounds great in my garage through some cabs.
Could I use it on its own in my studio via the direct out on the back without any speakers connected?
If so,I take it it could go direct into my computer set up without a DI box?
GRAHAM99
Posts: 305 Joined: Fri Nov 15, 2002 12:00 am
Re: Hartke HA2500 Bass Amp
Strange manual. The front and rear panel drawings don’t show a DI output, but the block schematic does and it’s in the specification list.
According to the schematic, the DI is positioned just before the master volume control, so you could leave the speaker(s) attached and turn the master volume right down.
Most solid state devices are happy to be used without speakers attached, but it does depend on the circuit used. Ef37a will say that they can sometimes go into oscillation and burn out, but it’s nothing I’ve ever cone across.
Weird that they omitted the DI out from the rear panel drawing... but it definitely exists:
Posts: 43701 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by GRAHAM99 »
Definitely does!
I don’t have the room in my little studio for the cabs but would love to use the amp for recording!
GRAHAM99
Post by Aled Hughes »
Not an snwer to your query, but this is why I love my little Ampeg PF20T bass head - it can run safely without a speaker cab attached, giving me a massive posh all-valve DI box for bass and other stuff.
I foolishly sold my first one, and just bought another, and this one's staying!
It also sounds very sweet through the little Ampeg 1x12 cab I have with it.
Aled Hughes
Can you justify a little 1 x 12" (or even a 1 X 10") like Aled's? I find practicing in the studio much nicer through 'proper' speakers and have a little Warwick 1 x 12" combo which I record using the DI but monitor through the speaker.
Like Wonks I've never (knowingly) blown up a tranny amp through running it without speakers connected (though I've blown a couple up with the speakers connected :oops: ) so with the master turned right down I think you'll be fine.
Posts: 22911 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
The amp's own protection system disconnects the speaker(s) if there's a problem, so the amp is clearly quite happy and stable with no load.
Post by GRAHAM99 »
Thanks for all the help.
I will get it plumbed in!
GRAHAM99
Hugh and Wonks are almost certainly right but it happened to me!
I am sure people will get away without a load on a transistor amp 99.99% of the time but where an amp is being run permanently in such a way surely it makes sense to put one of these https://store.brightcomponents.co.uk/pr ... w-8r-100w/ in a tin?
The absence of a load in the hi fi/studio world is probably harmless because the amplifiers are rarely if ever driven into hard clipping. This is a regular occurrence for guitar amps. Not so much for bass but. 'it'appen.
The other no-no for solid state amps is big transformers. These have a very low winding resistance and so even a small output offset voltage results in a steady current which can lead to thermal runaway.
So with the master volune turned right down so there’s no signal for the amp stage to amplify (except any residual noise), all should be fine.
Post by BigRedX »
As others have said it will almost certainly be fine without a cab attached for the purposes of getting a DI signal out.
However, for bass guitars the cab(s) have a significant influence on the sound that your hear, I would say that for a bass rig without a valve power stage the cabs contribute about 50% towards the sound that you hear, and therefore without them your bass will not sound the same. In this case it will come down to how much you like the sound of just the pre-amp tone shaping circuitry and what processing you intend to apply post recording.
BigRedX
Posts: 3125 Joined: Fri Sep 03, 2004 12:00 am
