Amplitube5 question
Amplitube5 question
Post by paleface »
hello all
ive got a question regarding amplitube5
when im using a single amp it still has a stereo channel in the mixer section
for the room mics
should i be using the waves s1 to monoize the said track
before i put it through the waves real adt plugin?
and if i dont use the s1 should the effect i do use after be stereo?
paleface
Posts: 198 Joined: Thu Jun 12, 2008 12:00 am Location: midlands
Re: Amplitube5 question
What do you plan to do with the original and ADT signals in terms of stereo panning (if any)?
Posts: 19211 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Post by paleface »
hello
i would be panning the adt somewhere between 60 % to fully left and right
paleface
If you put amplitude on a mono track, then the output will be mono regardless of any stereo functionality internally.
You’ve then got the option of duplicating the track and adding ADT on that in full wet mode, or you could set the ADT up as a send effect (full wet). I think the first option will give you better stereo positioning as the FX send tracks are normally stereo, but with a stereo combined panner instead of the standard balance panner, you can control the width of anADT send track.
Other methods are available.
Post by paleface »
hello wonks im using reaper
and ive just read up that it defaults to stereo
and the track width narrows to mono
paleface
