Bluetooth Page Turner
Post by Scouser »
Anyone had any experience with Bluetooth page turners ?
There seem to be so many I am looking for something to work with the app songbook pro..
Are they all equal ? I don't need anything other than a page turner ...
Scouser
Posts: 842 Joined: Mon Oct 04, 2004 12:00 am
Re: Bluetooth Page Turner
Post by Bob Bickerton »
I use the Airturn https://www.airturn.com/collections/bl ... ls-remotes, including the Ped-Pro and BT500S-2. The Ped-Pro is silent and is probably my favourite of the two, but the BT500 is more like a guitar pedal action if that’s what you prefer.
Most chamber musicians I’ve come across use the Airturn pedals.
Bob Bickerton
Posts: 5639 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
I use AirTurn pedals too when I need one. They just seem to work (with an iPad).
Post by shufflebeat »
https://www.amazon.co.uk/QIONGHA-Choco ... 9823534287
4 buttons I use as:
Previous page
Next page
Previous song in set
Next song in set.
iPad/songbook pro
I think I must have persuaded about 6 friends to buy these, wish I was on commission.
shufflebeat
Post by Scouser »
Hey shuffle, was reading that the pedal can be difficult to set up, did you find this to be the case. Sometimes the problem with things like this can be it does many things when you only want it to do one…
Scouser
There is an app (simple or advanced mode) in which you select one of several presets, if memory serves it chooses between, “up, down, left, right” or, “space, enter, page up, page down” or the like and caters for connecting with devices that can’t assign trigger to outcome but SBP doesn’t have an issue with that so, in settings/footpedals, you:
* add trigger
* press button (SBP recognises)
* assign function
* repeat x3
done.
shufflebeat
Post by Scouser »
Hey shuffle, wondered if you might have my advice, struggling to get choc wireless controller to do anything ? Downloaded CubeSuite selected what I thought was correct preset went into songbook pro to configure footswitch, done everything I thought I would need to do, but nothing ?
Scouser
I don't know what combination of devices/software you're using?
I use a M-Vave Chocolate as a page-turner with forScore on an iPad with no problem.
Post by ghellquist »
Have been using Pageturn Duo 500 with my iPad and ForScore for a few years and not having any problems. Playing in a symphone orchestra it has to be, and is, silent. Only the blue Led always blinking is annoying -- a bit of gaffa tape solved that.
Recently I have acquired a no-name from Thomann, Thomann pageturn pedal, at about 1/4 price -- it works equally well in my experience.
ghellquist
Posts: 87 Joined: Thu Sep 09, 2004 12:00 am
Scouser wrote: Wed Jul 16, 2025 9:18 am Hey shuffle, wondered if you might have my advice, struggling to get choc wireless controller to do anything ? Downloaded CubeSuite selected what I thought was correct preset went into songbook pro to configure footswitch, done everything I thought I would need to do, but nothing ?
Sorry, seem to have missed this, crazy month. If you’re still hitting a brick wall I’ll get back in a day or two and explore your setup and settings.
shufflebeat
I'm trying to set up a cheap, AliExpress, BT pageturn pedal to control Loopy Pro on my iPhone. With a BT speaker it works well enough recording the guitar 'via the mic and replaying through the speaker while I solo live/acoustic over the loop. The problem I'm having is getting clean/accurate start/end points to the rhythm loop.
In my case the pedal is this one https://www.aliexpress.com/item/1005009 ... ry_from%3A
Connecting it up was simple but I'm struggling with the latency.
