IEC C7 to IEC C13 converter safe for equipment?
Post by Michael Dow »
Hi guys, i've got a power conditioner that puts out only the standard 3 pin IEC C13/14 connectors. But i have an SPL vitalizer that has an input of the 2 pin figure 8 style connector
Is it possible to use a converter safely? Or will it cause a problem?
Michael Dow
Posts: 838 Joined: Thu Aug 28, 2008 12:00 am Location: Sydney
Re: IEC C7 to IEC C13 converter safe for equipment?
Just get a C14 to C7 lead and you'll be fine.
E.g. https://www.lindy.co.uk/cables-adapters ... able-p9190
Wonks wrote: Tue Jun 24, 2025 7:56 am Just get a C14 to C7 lead and you'll be fine.
Yes! That makes much more sense. It's funny when ones brain doesn't work properly and think of the obvious isn't it!
Thank you :mrgreen:
Michael Dow
You can get adapters, but it’s always more reliable to use a single lead/cable designed for the job.
Wonks wrote: Tue Jun 24, 2025 10:34 am You can get adapters, but it’s always more reliable to use a single lead/cable designed for the job.
Exactly!
Posts: 20882 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
