To do this I decided to fit the Locking nut, I carefully filed a nice flat shelf, was so proud, till I dropped the Nut into position and realised it needed to be at an angle!
glued a piece of rosewood back in and set back to work
After roughing it in with files, I used double sided tape to put sandpaper on the back of the Nut and used it as a, super posh, filing block!
(painters tape in position to prevent losing any material from the first fret to the nut)
..went to gently screw down the nut (had pre drilled holes) and the bolt sheard!
Much bad language ensued!
Luckily, heating the stub of the screw with a soldering iron and letting it cool, then pliers managed to ease it out!
