Firewire interface with M4 Mac Mini?
Post by _ Six _ »
Hi all.
I'm buying a new M4 Mac Mini but have a Firewire 400/800 interface. Is it possible to get a docking station that will allow me to use my audio interface or do I need a new one?
The Mac Mini only has USC-C and Thunderbolt 4 connectivity. My interface is a Focusrite Sapphire Pro 26io
Thank you
Six
_ Six _
Posts: 823 Joined: Sat Jun 03, 2006 12:00 am
Re: Firewire interface with M4 Mac Mini?
Post by OneWorld »
Well as long as there is a market for something that will connect a plug for this to connect to a socket for that there will always be some sort of gizmo that claims to do it, with about as much success as turning water into wine I would think.
Thing is, a decent convertor will possibly cost more than what your Focusrite is worth and added to that there are legions of worthy USB 2 interfaces available nowadays.
I had an RME Fireface 800 which I was ever so reluctant to let go, but my new PC didn't offer a FW option, well, not with out a lot of messing about, I dropped lucky and got a TASCAM USB 2 equivalent and to my delight it performs just as well, so I sold the FF800 while it still had some value.
Another thing with buying a convertor is you have to factor in an unknown quantity in the mix. Yes it might well work, but will it preserve the same latency figures etc
Yes have a go by all means, but they do say "Don't try this at home folks"
OneWorld
Posts: 5962 Joined: Tue Apr 07, 2009 12:00 am
Post by ConcertinaChap »
Apple used to make a Thunderbolt 2 to Firewire adapter that you might be able to find second hand and that in conjunction with an Apple Thunderbolt 2 to 3 adapter would in theory make the connection but including suitable Thunderbolt cables would make the whole chain pretty expensive, the wrong side of a hundred pounds I'd guess. And if you can get a suitable driver for your interface would it work with this chain?
I'm sorry, but I have to agree with OneWorld. It's time to move on to a new interface.
ConcertinaChap
Posts: 15248 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Making music: Eagle Alley
Buy an RME Digiface USB and use your Focusrite as the A-D and D-A. That's what I do with my Pro26io.
Posts: 16993 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Focusrite won't have any drivers that will work on an M4 Mac. They walked (well, more like ran) away from Firewire a long, long time ago. So definitely forget Firewire and either get an RME Digiface as suggested and use it over ADAT or get another interface. How many inputs/outputs do you actually need these days, Scott?
Posts: 19211 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Wonks wrote: Sat Apr 05, 2025 5:04 pm Focusrite won't have any drivers that will work on an M4 Mac. They walked (well, more like ran) away from Firewire a long, long time ago.
I can confirm this, IIRC my Pro24 ran out of drivers before the 2011 MBP ran out of OS upgrades...
Posts: 22920 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by Tomás Mulcahy »
James Perrett wrote: Sat Apr 05, 2025 1:27 pm Buy an RME Digiface USB and use your Focusrite as the A-D and D-A. That's what I do with my Pro26io.
I love that this is a viable solution.
Tomás Mulcahy
Post by s_e_a_n »
I had been meaning to try my MOTU 828 mkII FW with my new M4 Mini for a while and hadn't got around to it. It's 18 years old so I wasn't expecting much. Following this topic on the motunation forum however I got it working last night... seems fine.
https://www.motunation.com/forum/viewtopic.php?t=68313
I have two adapters, TB4->TB and TB->FW800 then a FW800->FW400 cable.
It's a lovely interface and I have two of them which I've used since new for all sorts of projects but I suppose at some stage I'll have to retire them. Will be hard to find the same quality of build nowadays though.
s_e_a_n
Posts: 71 Joined: Thu Apr 03, 2003 12:00 am Location: Kerry
Programmer, sound engineer, artist, musician
Interesting. That was the chain of adapters I was suggesting but I was rather pessimistic that it would work. Nice to know it would.
ConcertinaChap
Post by mumblinstevedubya »
I too have got the double dongle method working with a macbook pro M4 and my 828 Mk2
The dongles can be expensive (on the 2nd hand market) but I shopped around until I found someone selling an old FW interface with dongles.
I kept the dongles and sold the interface on….
Good luck!
mumblinstevedubya
Posts: 24 Joined: Mon Jan 27, 2003 12:00 am Location: East Sussex
Post by deJerry »
Hy,
I upgraded my Mac Mini M1 to an M4.
My mixer Behringer X32 was connected wia firewire to thunderbolt by a Mac adapter and it runns great for years.
No i tried to connect the same mixer by ading a thunderbolt 2 to thunderbolt 4 adapter, but the mac M4 can`t find my X32...
So I decided to try the easyest way, I bought an USB 2.0 to USB C cable.
The mac can find the mixer, but after some minutes the sound starts to turn into noise. After disconnecting an reconnecting the usb-c plug it`s ok for some minutes and then the same game starts over and over again...
Does anibody knows why this can happen?
Thanx in advance,
Jerry
deJerry
Posts: 1 Joined: Sun Jul 27, 2025 5:39 pm
Do you still have the M1 Mini? It might be worth trying connecting the X32 to that using the USB cable and see if the issue disappears. I never liked the idea of using a chain of adapters to make a firewire device work on an M series Mac, so I'm not entirely surprised that yours is giving trouble.
I use an X32 and have just upgraded my studio computer to a 2019 Mac Pro but it's intel powered so probably not much help to you. I could try my M1 MBP if you no longer have your old Mini but I won't be home until later this week and may not get chance then (after which it will be September I'm afraid).
And, welcome to the forums BTW... :thumbup:
Post by fatbenelton »
I can’t see that anybody mentioned this so forgive me if I missed it.....
The main issue is that Apple dropped firewire support from core audio a couple of operating systems back. From Ventura on.
What this means is that interfaces that relied on core audio - ie plug and play - will no longer work, no matter what dongles you use. This included the original Mackie Onyx/firewire mixers as I found out to my cost!
If the interface required custom drivers then it may work with a combo of thunderbolt 3 to tb 2 to firewire adapters, so long as the company has updated and maintained those drivers to work with the latest operating system. At a guess, I would say that nobody will have done that except perhaps RME.
So...
Core Audio products - no chance
Interfaces with custom drivers - possible if drivers updated recently.
Short answer is - highly unlikely to work.
fatbenelton
Posts: 708 Joined: Thu Aug 22, 2002 12:00 am Location: Liverpool, UK
Jonny
Post by ManFromGlass »
Mid range M4 laptop here. I bought a used thunderbolt to firewire box. My ancient RME Hammerfall Multiface is rocking along inside it. 8 analogue in/outs. RME even had a firmware update for it. There was enough room in the converter box for an Nvme drive for all my samples.
Posts: 7866 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
Post by Johnsy »
ManFromGlass wrote: Sat Sep 27, 2025 2:13 am Mid range M4 laptop here. I bought a used thunderbolt to firewire box. My ancient RME Hammerfall Multiface is rocking along inside it.
Though it uses a Firewire cable/connector, the Multiface/Multiface II isn't actually a Firewire interface, ie, it doesn't use the FW protocol (it really is ancient! :) ).
On the more general point: Fatbenelton is absolutely right. If the OS doesn't provide a working FW stack, then no drivers or dongles will help you.
Johnsy
Posts: 572 Joined: Tue Apr 06, 2004 12:00 am
And the latest Apple OS has dropped legacy Firewire support completely. So you can use the previous versions and Firewire should work, but with the newest version you'll get nothing (though with companies like RME that produce their own drivers, you'll have to check on an individual product basis).
Post by Johnsy »
Wonks wrote: Sat Sep 27, 2025 8:37 am (though with companies like RME that produce their own drivers, you'll have to check on an individual product basis).
If there's no FW stack, not even RME can save you.
Johnsy
ManFromGlass wrote: Sat Sep 27, 2025 2:13 am I bought a used thunderbolt to firewire box.
Do you really mean a Thunderbolt to PCI/e box? As Johnsy says, the Multiface connection isn't a standard Firewire connection.
Post by Johnsy »
James Perrett wrote: Sat Sep 27, 2025 10:38 am
I assumed that's what he must have meant, James. I can't see what else it can be.
Johnsy
Doh! Yes that is it. Apologies for any confusion.
I guess I’ll play the Seniors Moment card right now :)
Post by Johnsy »
ManFromGlass wrote: Sun Sep 28, 2025 2:10 am Apologies for any confusion.
Think nothing of it MFG... If I'd spent that long plugging a Firewire cable into a Firewire connector, I think I too would have long forgotten that I wasn't actually using Firewire! :)
Johnsy
