I have an Audient iD4 as my DAW interface (Windows 10) and have been having problems with the signal path entering the Audient, either as an input or output signal, and dying inside there. A signal will leave my Kemper, go into the Audient and the LED indicators will show a signal being received, yet nothing arrives at my PC. Or I'll attempt playback from my PC, my DAW indicators will show gain, the Audient interface will show gain, yet I hear nothing in my Headphones etc.
Basically, despite everything visually working as it's meant to, there is no sound.
I am not sure what causes this problem, but the solution is that you have to go into the Audient interface on your PC, and jiggle all the sliders slightly. No, not the physical knobs on the box, they do nothing, you have to move them on the PC. Like, literally just wiggle the sliders on the screen up and down. Then it will suddenly work.
I know, I don't get it either, but it's as if they get "stuck" somehow and by moving them, suddenly the gain gets reset to the correct level.
Then it will work correctly for the rest of your session. Until next time you power up your computer and have to do it again. In fact it's the first thing I do when I turn on my computer, go into the ID4 interface, and jiggle all six sliders, Mic 1 and 2, DAW 1-4, otherwise, no sound.
Hopefully this saves someone some stress, it took me forever to find a fix.
Apart from this glitch, it works fine, and I have no idea what causes it.
