Simple question for you MIDI gurus
Post by Ben Asaro »
I have two identical model synths coming in (MIDISID) that are multi-voice on MIDI channels 1-6. I will have each unit connected to a different sequencer.
How to I keep the sequencers in sync whilst NOT passing MIDI not information through the second sequencer? Is this a LOCAL ON/OFF kind of thing?
Diagram for reference:
Is there a better way to connect this? I'm remedial at best when it comes to MIDI stuff, so any assistance would be appreciated.
Thanks!!
Ben Asaro
Posts: 3480 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Re: Simple question for you MIDI gurus
What make and model are the sequencers? Can you control whether the note information goes through the sequencers? I would have expected that to be a setting somewhere.
Posts: 16986 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by Ben Asaro »
James Perrett wrote: Mon Aug 25, 2025 7:52 pm What make and model are the sequencers?
Sequencer 1 is a NerdSeq
Sequencer 2 is an MC-50
This is kinda my question. Is that what I should be looking for?
After doing a bit more digging, it looks like most sequencers will not pass MIDI note data but will accept clock when set up in a mother/daughter config when they are in sync and not in record mode. Don't know how true that is but I'll test it and report back!
Thanks, James!!
Ben Asaro
Looks like you need pages 57 to 59 of the MC50 manual (plus a bit of experimentation because they don't seem to give all the options).
Post by Ben Asaro »
James Perrett wrote: Mon Aug 25, 2025 8:11 pm Looks like you need pages 57 to 59 of the MC50 manual (plus a bit of experimentation because they don't seem to give all the options).
Thanks, James!
Ben Asaro
Post by BillB »
https://www.muzines.co.uk/articles/rola ... mposer/761
The MC50's rear panel also provides the same features as the other MCs: MIDI In, Out x 2 (independently addressable) and Thru sockets, metronome output socket and level adjust knob, start/stop and punch in/out footswitch sockets, and tape sync in/out sockets.
Additionally, you can set one or other of the MIDI Outs to soft Thru, and determine for each Out whether or not MIDI clock, All Notes Off and Active Sensing will be transmitted.
So, if you use the MC-50 as master, you could use one of the MIDI outs to send clock data to the NerdSeq. Alternatively set the NerdSeq as Master sending to MC-50, and use the MC-50 Thru / soft Thru to determine what gets passed on or filtered out. Probably no need for the Quadra Thru.
BillB
Post by Ben Asaro »
BillB wrote: Tue Aug 26, 2025 2:49 pmhttps://www.muzines.co.uk/articles/rola ... mposer/761
Thanks, Bill!
Ben Asaro
Post by Ben Asaro »
Looks like this can be addressed with the Soft Thru settings on the MC-50.
Thanks, Bill!
Ben Asaro
Post by BillB »
BillB
Post by Ben Asaro »
Testing the MIDI THRU on the JV-10180 into the Analogue Pocket, it works perfect! Unfortunately, the MIDISIDs only have a single 5-pin MIDI IN, so I don't think I will be able to get around using a Quadra Thru as one synth will be fed directly from the NerdSeq while the other two only need MIDI Clock.
Testing continues!
Ben Asaro
