Windows 10.end support
Re: Windows 10.end support
Or Windows+Shift+S then drag to size if you just want to get part of the screen.
Post by OneWorld »
I use the Windows Snipping tool for that, works fine.
Oh yep, Win+Shift+S does the same job, that's useful, I predict you will go far
OneWorld
Posts: 5958 Joined: Tue Apr 07, 2009 12:00 am
James Perrett wrote: Fri Sep 26, 2025 11:55 am
ef37a wrote: Thu Sep 25, 2025 4:14 pm And I am yet to work out how to do a screen grab.
That hasn't changed for many many years. Alt-PrintScreen for the active window or just the PrintScreen button if you want full control over the area to be grabbed.
Yup, got that bit it was when I went to Paint 3D that the trouble started.
I shall have another look but W11 for me is like dressing a wound. You know you have got to get on with it but keep putting it off!
ef37a wrote: Fri Sep 26, 2025 2:05 pm Yup, got that bit it was when I went to Paint 3D that the trouble started.
I put Irfanview on all my computers to handle pictures so I've not used Paint in ages.
Posts: 16988 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by resistorman »
Interesting tool called UpDownTool mentioned in this article:
https://www.pcworld.com/article/2919734 ... s-how.html
resistorman
Posts: 2987 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
resistorman wrote: Fri Sep 26, 2025 10:11 pm Interesting tool called UpDownTool mentioned in this article:
Though, from what I've read in the last couple of days, that article is a little out of date because you can now join the Windows 10 extended support program without a Microsoft account which gives you another year of support.
James Perrett wrote: Fri Sep 26, 2025 10:41 pm
True for Europe not US :) The UpDownTool installs Windows 10 LTSC which can give support up to 2032 :wtf:
resistorman
Post by Guitarking »
Does anyone have good experiences with going from windows 10 to windows 11 on a non supported pc, using it for pro audio?
Guitarking
Posts: 299 Joined: Sat Jan 09, 2010 12:00 am
Guitarking wrote: Thu Dec 11, 2025 10:59 pm Does anyone have good experiences with going from windows 10 to windows 11 on a non supported pc, using it for pro audio?
We've had a couple of computers in this house that weren't officially supported but came with 11 installed by their refurbishers. I have also upgraded my living room computer from 10 to 11 using Rufus. The living room computer is mainly used for stereo recording but I've used it to do 24 track mixes with no problems.
Now that I'm used to it and have tweaked a few settings, I'd say that 11 is better than 10.
So no instability issues?
Guitarking
None for me and I've done it to three computers. It extended their working life for another couple of years and then other issues caused their replacement.
Guitarking wrote: Thu Dec 11, 2025 11:16 pm So no instability issues?
None at all.
What is the best way to upgrade/install w11 on a non compatable w10 machine?
Guitarking
Guitarking wrote: Fri Dec 12, 2025 7:43 pm What is the best way to upgrade/install w11 on a non compatable w10 machine?
I used an online guide similar to this one
https://theideaplace.net/using-rufus-to ... -hardware/
I found that I had to enable UEFI on my computer - fortunately my lad went through a phase of trying to write his own operating system a couple of years ago so he was very familiar with UEFI.
While I made a backup of my Windows 10 system disk as a precaution, I found that the Win 11 installation kept just about all of my programs and settings.
Post by Marbury »
My WIndows 10 pc is now showing the time as 04.10am when it is in fact 12.29
Marbury
Posts: 1136 Joined: Thu Aug 28, 2003 12:00 am Location: Cheshire, UK
Post by Nazard »
I use Meinberg NTP, (Network Time Protocol), for syncing my PCs and it will work fine on Win 10.
https://www.meinbergglobal.com/english/ ... ntp_stable
Nazard
Posts: 796 Joined: Sat May 15, 2010 12:00 am
Marbury wrote: Tue Dec 16, 2025 12:30 pm My WIndows 10 pc is now showing the time as 04.10am when it is in fact 12.29
Battery backup on he motherboard is dying. Replace asap.
Post by Marbury »
Is that the round cmos battery ? I wonder if it's causing issues with it stalling a few times at boot up.
Marbury
Marbury wrote: Tue Dec 16, 2025 3:07 pm Is that the round cmos battery ? I wonder if it's causing issues with it stalling a few times at boot up.
Yes, it is very likely to be the cause of your boot problems. If a BIOS value has been corrupted then it could cause all kinds of strange behaviour. If the battery voltage is marginal then not all memory locations would be affected so you may not have noticed the problem initially by looking in the BIOS.
Post by OneWorld »
Then best thing about swapping our the CMOS battery is that it is and easy change to make and an inexpensive one, and the results of swapping it out are instant and it then factors out/in one of the possible causes of a fault, you're taking an unknown out of the equation.
Another easy check is to make sure all cables are correctly seated. When experimenting it is important to make sure every possible potential cause of trouble is attended too. It is amazing how computers can be so finnicky at times, but given the complexity, it sometimes surprises me that they work at all
OneWorld
