Hello,
I'm recording a classical vocal performance, but unfortunately we didn't get the chance for a sound check. As such, I'm running very low gain to avoid clipping.
I'm going to need to do some noise reduction to control the hiss, should I do the noise reduction before normalizing or after? What is the best practice?
Thanks,
Peter
Salvaging a under recorded source
- twotoedsloth
Frequent Poster - Posts: 1136 Joined: Sat Jan 26, 2008 12:00 am
Re: Salvaging a under recorded source
I would always do noise reduction first, give it the most unadulterated signal to work on and it will generally work at its best.
Thanks for your advice. It does seem solid.
The only problem that I've encountered in the past is that the piano tails fade out to the noise floor, so with a normalized sound print there's more to work with. I can't check this now, as the concert is still going on, but I'll do both and compare the results.
Again, thanks for your reply,
Peter
Peter
- twotoedsloth
Mathematically it should make no difference to a good noise reduction algorithm whether you use a normalised signal or the original level. However, your mention of tails disappearing makes me wonder whether you are using a crude noise reduction algorithm or if you are trying to do too much noise reduction in a single pass.
Noise reduction is the one area where I've found RX hard to beat.
Posts: 16989 Joined: Mon Sep 10, 2001 12:00 am
twotoedsloth wrote: ↑Fri Oct 24, 2025 8:07 pmI'm recording a classical vocal performance, but unfortunately we didn't get the chance for a sound check. As such, I'm running very low gain to avoid clipping.
What's the highest recorded peak level?
It would be unusual to have a noise problem due to the (professional) gear. It's normally ambient room noise that dominates.
Shouldn't make any real difference... but I'd normalise to -6dBFS and then process, personally. And two or three passes with 4-6dB noise reduction each generally sounds better than one pass with 12-15dB noise reduction.
Peter
[/quote]
Hello,
Thank you for your help with this.
Now that the concert has ended, I looked at the file, and the peak level is -19db. I usually normalize to -3db. When I was recording the level looked much lower than -19, which is why I wrote the original post. Now normalized, there really isn't that much noise, so I'm not going to worry about it.
If someone complains, I do have options, I have licenses for the ancient DINR, the equally antiquated Sound Forge NR, and the one I've been using for many years now: Izotope RX. I will try your method of multiple passes next time!
Many thanks,
Peter
Many thanks,
Peter
- twotoedsloth
twotoedsloth wrote: ↑Fri Oct 24, 2025 11:07 pmNow that the concert has ended, I looked at the file, and the peak level is -19db.
I wouldn't call that 'under-recorded' at all. Ideally, a rehearsal would have allowed you to get maybe 10dB louder, but that peak level is certainly not an issue in a 24bit recording.
I have live choir recordings with solos/duets barely peaking -30dBFS, but they're still well above the electronic noise.
I'd agree!
It really does help if you need heavy NR.
