As far as I can make out, 207.5 MHz isn't a license exempt band in the UK. I don't know if you are in the UK, but I'm pretty sure the mics are working on a frequency that needs a license.
So if in the UK, unless you go and get a licence, you could end up with a hefty fine.
The speaker really seems to be best suited for basic music playback, not as a vocal or instrument PA system.
I'd guess its a QTX 12" (or maybe 15") 100W (50W +50W, so effectively nearer 70W output) portable PA system, that costs around £180-£200. Or possibly the same unit under a different brand name. From a UK store, it should have come with mics in the UK licence free VHF band.
Datasheet for the QTX version here:
https://www.farnell.com/datasheets/3678843.pdf
(if you aren't in the UK then you'll need to check the mic frequency is suitable for use in your country).
The manual doesn't say whether its mic inputs are for high or low impedance mics. But as one input is also for 'guitar' (though they don't say if this is electric guitar or the input from an electro-acoustic guitar with a built-in preamp). The mic inputs certainly don't provide phantom power and there are no individual mic gain controls, just a combined level control for both mics.
If this is all you have and can't borrow a better PA, then you'll have to use the radio mics (the speaker should have come with two, so I hope you have both). You'll need stands for them and they'll need to be positioned quite close to the violins.
If you only have one radio mic, then trying to mic up the performance through a not very loud speaker is going t cause you more hassle than it's worth, so I'd recommend sticking to a pure acoustic performance.
