I'm an experienced computer user, but have relatively little experience using Windows with a DAW.
I had a configuration that was working well a year or so ago but I recently started using it again and now have a problem that has defeated me, and a couple of friends with more experience than me in this area.
My standard set up is a windows 10 computer (version 22H2 if that matters) with a Mackie ProFX6v3 attached via USB and Reaper as my DAW. I have the latest Mackie driver installed and the latest Reaper version. The problem is that everything that goes to the Mackie as output (channels 3 and 4) is coming back on the input channels 1 and 2. Whether it's the metronome or playback of other tracks. Even general computer audio (which is also set to use the ProFX channels 3 and 4 to use the monitors) shows up as input. Input on channels 1 and 2 is working as it should, but intermixed with the unwanted output signals.
So far I have tried the following:
- Checking and double checking the driver settings and routing matrix
- As mentioned, uninstalling and reinstalling the latest Mackie driver, Reaper version, and taking all driver updates from Windows Update
- Swapping the Mackie for a small Berhinger mixer which uses completely different drivers (not ASIO)
- Using Audacity instead of Reaper
My next recourse (short of buying a new computer) is to re-install Windows from scratch or see if I have a recovery point that works, but this is a general use computer so I would really rather not.
Can anyone suggest what on earth might be going on?
Thanks,
Mike
