awjoe wrote: ↑Thu Jan 29, 2026 5:44 am
I think this is the first time that plugins I use have headed toward oblivion.
How often does this happen? Is it happening more frequently?
For me at least, quite a lot over the years, especially on Windows. Activation servers go offline, Windows stops running VST's completely or the GUI breaks. I forget the name (synthmaker?), but there was a development platform used to develop a lot of freeware plugins and many were quite fun, but when multi CPU hardware became common place, a lot of plugins broke and needed a recompile with a newer version, which didn't happen for a lot of things because people had moved on, stopped working on them.
If you're a Waves user then that $29.99 deal will soon turn into a support package costing significantly more. You might get lucky and have a few years, but you're only ever one Windows update away from being shafted, although that's true of anything running on Windows.
For various reasons we have to use a very old version of the Audio Precision test software, so constantly have to uninstall a Windows .NET update that breaks it. The cost of updating to a newer version is near 10K, just for us, let alone the cost of updating the production lines (air gapped running Win 10)
I was an EMU - X2/ X3 user years ago, I had a lot of sample CDs. When it came time to move to a new laptop, that was the end of that. I did eventually find a cracked version that does install, but obviously that was a risk tried in a sandbox before letting it near my main one. Most of the CDs still read, but some fail the piracy check.
I had a piano library that can no longer be activated. There was a way of importing the samples into Kontakt, but it never quite worked.
Maintaining software and servers is expensive and when the OS decides to deprecate APIs or features (no 16 bit code on Windows, security lock downs, .NET updates and so on) then developers are often left with a large rewrite, huge test matrix, which users, understandably, are not happy about paying for.
I've had to suffer the single Native account login migration when they bought Izotope and others, that required tech support intervention, if the companies get spun off, then that could all revert again.
I have a friend who joined NI only a couple of months ago, it didn't sound great before this recent event. There seems to be a lot of "we've always done it this way" inertia to overcome.
I have quite a lot of NI, Izotope and Plugin Alliance software, but I'm well aware that any of it could stop working at any point and old projects may no longer load. I've still not moved off Windows 10 because I've got an ongoing project and there is no benefit but plenty of risk to moving to Windows 11.
At some point the laptop will die and I've already maxed out the RAM, which is starting to be a limitation. I don't have a lot of faith that everything would install, activate and run on a new one. iLOK will help with some plugins, but others have their own methods and a limited number of activations - just thinking about reinstalling IK plugins gives bad flashbacks.
I find I'm much more forgiving of hardware when it breaks, it's usually been long lived, given good service, sometimes can be repaired and pressed to give a few more years service and generally doesn't care who owns the company today. Sudden software death feels a much more personal slap in the face, perhaps I've just been burned too many times.
Joe
