SafeandSound Mastering wrote: ↑Tue Feb 03, 2026 11:23 amNow, you might be the kind of man that could toss a little girl's teddy into a pot of boiling water, but I couldn't.
Your words, not mine. I suggest you reflect on them carefully, if it is possible.
I will give benefit of doubt for that insult and consider your response being emboldened by being anonymous. You simply weaponised my response out of context.
There is no point adding anything to this as it descended into reactionary nonsense and why I felt it was the right time to rest where I did, the correct judgement, proven perfectly.
Clearly the diverse nature of the creep is going to move so widely across every aspects of society it is quite difficult to pin down the conversation to music specific consequences alone. Some may be good, some may be bad, and then there will likely be the equivalent of the underground which will to entirely unknowable. Just a few rogue operators may have the potential for unknown and unlimited damage.
Let's hope data / access security / is as well funded as the rest of it.
The consequences are unknowable and that is why caution and awareness of the highest level is both the goal and aim.
I will no longer make any commentary on anything surrounding this very broad topic. I have much more important things to be doing like mastering music at the highest level.
None of us are or will be in control of any of the outcomes.
On this matter I wish everyone the best including OneWorld.
On reflection - I didn't write you 'were' I wrote you "you might" be two different things, just the same as saying "pigs might fly" It's a turn of phrase oh Master.
"On this matter I wish everyone the best including OneWorld."
I have to admit, I've had a look at what services you offer, and genuinely, joking aside (yes, even I can be 'serious' on occasions, but it's a struggle) I am well impressed. You are clearly on top of your game.
