Valeton GP-5 -- astounding bang for the buck!
Post by Ben Asaro »
I picked up the GP-5 on the advice of a friend when I told him I want to get the smallest rig possible for jamming/rehearsals.
I'm pretty blown away with this little unit! I've only set up one preset so far, using stock IRs, and it does exactly what I need it to do.
https://photos.app.goo.gl/qPUQQLbuRykdtK2v6
Ben Asaro
Posts: 3485 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Re: Valeton GP-5 -- astounding bang for the buck!
Post by BillB »
Very cool, Ben. I picked up a GP200 LT, cheapish second hand. Very nice unit, but the GP50 is nicely compact. Valeton have really hit the mark with this series.
BillB
Posts: 2469 Joined: Mon Apr 07, 2003 12:00 am Location: East Yorkshire
Post by Telemaxis »
Was rehearsing with a couple of friends earlier today - one of whom had got hold of a GP5. He kindly let me use it for the whole session - and it was excellent. Highly recommended!
Telemaxis
Posts: 71 Joined: Thu May 21, 2020 10:11 pm Location: Cumberland
Post by Matt Houghton »
We reviewed it in SOS Oct 25. John Walden seemed equally blown away...
Matt Houghton
SOS Reviews Editor
Post by adrian_k »
I’m wondering if there is any noticeable latency when using the cap IRs? I have similar small unit that has great sounds but the latency on cab emulation makes it pretty unusable.
adrian_k
Posts: 3817 Joined: Thu Jan 30, 2003 12:00 am Location: Gloucestershire
Life is wealth. (John Ruskin)
If Max/StudioSupportGnome happily uses it for a backup live rig, then it’s useable.
Post by Random Guitarist »
adrian_k wrote: Wed Feb 25, 2026 5:00 pm I’m wondering if there is any noticeable latency when using the cap IRs? I have similar small unit that has great sounds but the latency on cab emulation makes it pretty unusable.
Quoted latency that I have seen is around 5mS, I have the gp200 as a battery powered option for open mics, I have not experienced latency issues and find it an enjoyable unit to play.
Random Guitarist
Posts: 1207 Joined: Tue Apr 01, 2008 12:00 am Location: West Sussex UK
...Though you probably don't want to use it in conjunction with another digital pedal as the latencies add up.
Post by adrian_k »
Thanks chaps, credit card being assaulted to the tune of a GP-50 as I sit here. The box I have (Leo Jaymz Silverbox) I measured as 17ms with the cab IR switched on. Shame because it's otherwise very good, and used with the the cab emulation switched off and plugged into the FX return or line in on an amp is amazing for the money.
adrian_k
I'll be interested to know how much memory the looper has, realistically I need 90 secs or more but IIRC (I struggled to find out despite extensive googling) it only has about 40 secs even in mono.
Post by SecretSam »
You could try playing just over twice as fast. Then 40 seconds would be fine?
SecretSam
Posts: 3031 Joined: Tue Oct 29, 2002 12:00 am Location: Officially, I do not exist.
Instant gratification is actually pretty good. It's fast as well.
Post by Studio Support Gnome »
I got a gp5 a while back as an emergency back up all in one . Great little box , paired up with an Mvave choco plus pedal to expand the control options
My new monochrome bigger board has a GP50 on , as a result of the GP5’s astonishing value . It’s there partly as a NAM/IR tool , does a great job of acoustic simulator , but also frankly some of the amp models and cab models are worth using , holding their own against other kit on my board including two notes revolt and CAB , . I got the GP50 because it has real midi . So patch control integration is more practical than the GP5 . I have yet to try the looper . At present my entire hardware stock is packed up out of the way while plumbers gut the house for new heating system
Posts: 3025 Joined: Tue Jul 22, 2003 12:00 am Location: UK
Mostly Retired from Audio.... If I already know you I'll help,  if not....    Ask Hugh Robjohns, unless that is you're in need of 80's shred guitar... that, I'm still interested in having fun with...
Post by Aled Hughes »
Our pedal steel guitarist uses a GP-5 for live shows. I don't know how he has it set up, but it sounds great.
Aled Hughes
SecretSam wrote: Thu Feb 26, 2026 7:50 pm You could try playing just over twice as fast. Then 40 seconds would be fine?
You haven't been to a gypsy jazz jam have you :smirk:
Post by adrian_k »
Sam Spoons wrote: Thu Feb 26, 2026 7:06 pm I'll be interested to know how much memory the looper has, realistically I need 90 secs or more but IIRC (I struggled to find out despite extensive googling) it only has about 40 secs even in mono.
According to the manual - 20 seconds. Google Gemini told me 90 seconds. Maybe it read your post and got confused.
adrian_k
adrian_k wrote: Fri Feb 27, 2026 8:22 am According to the manual - 20 seconds. Google Gemini told me 90 seconds. Maybe it read your post and got confused.
I thought GP-5 has no looper, gp-50 and 200 have loopers, with 200 having more capacity?
Random Guitarist
Random Guitarist wrote: Fri Feb 27, 2026 4:19 pm
You're right. No mention of a looper in the GP5 user manual.
Post by BillB »
Not checked other manuals, but GP-200 LT manual says
Recording Time: When “Undo/Redo” are not required, you can select up to 180s recording time.
BillB
GP5 no loopy . GP50 does .
There’s also a dedicated looping pedal in a similar package format to the GP50 for the price of a GP5 , it’s called the VLP200
Post by adrian_k »
Very sorry for the confusion, I thought Sam was asking about the GP-50 that I had ordered, I was answering that question. :beamup:
adrian_k
According to the Valeton website, the VLP200 does up to 4 minutes of stereo file loops and can store up to 7 hours of recordings in total.
adrian_k wrote: Fri Feb 27, 2026 7:46 pm
You were right, that's why I replied directly under your post (had my reply not directly followed it I would have quoted it). The GP-50 has two buttons and a looper plus the ability to load IRs unfortunately 20secs loop time is not long enough.
Though to Sam’s audience it probably feels a lot, lot longer. ;)
Here is my minimalist emergency backup rig . I can genuinely gig with just this and guitar .
Wonks wrote: Sat Feb 28, 2026 7:27 pm Though to Sam’s audience it probably feels a lot, lot longer. ;)
Audience! What's an audience...? :bouncy::bouncy::bouncy:
