Interesting project
Interesting project
Post by ajay_m »
https://www.instructables.com/5-Fader-P ... -Motorize/
Now you can purchase 5 packs of x32 motorised faders for just over 30 quid, some interesting possibilities arise, as in this project. Very clever ...
ajay_m
Posts: 1681 Joined: Mon Jan 16, 2017 7:08 pm
Re: Interesting project
Post by onre »
If only these were audio taper! The project I had in mind was adding flying faders to my old analogue desk. Of course I could build a bank of 8 VCAs... so many ideas, so little time.
onre
Posts: 4 Joined: Tue Mar 05, 2024 12:28 pm Location: Tampere, Finland
U = R * I -- It isn't just a good idea, it's the law.
If you are able to edit the downloadable code, you can convert the linear value from the faders into a log curve value before sending its value out as a MIDI message.
Post by onre »
Wonks wrote: Fri Feb 27, 2026 10:53 am If you are able to edit the downloadable code, you can convert the linear value from the faders into a log curve value before sending its value out as a MIDI message.
Indeed. However, my pipe dream was to replace the group faders on my desk with these, retaining the current analog functionality and also being able to control the faders by sending MIDI messages to the desk. The group faders of my desk are in the signal path, so accomplishing this would necessitate either audio taper faders or building a VCA bank for the groups so that a linear-attenuated control voltage from the faders would result in logarithmic changes to signal level.
onre
There are more expensive options available, such as Penny and Giles motorised faders but whether they’d fit in the existing space available is another matter.
onre wrote: Fri Feb 27, 2026 11:12 am
If you have a very low impedance source you can get something vaguely resembling a log law :
---------[pot]----------------------------input of destination with (say) 1/20th pot value to ground
. |_____|wiper
Posts: 20887 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Folderol wrote: Fri Feb 27, 2026 12:56 pm
---------[pot]----------------------------input of destination with resistor (say) 1/20th pot value to ground
. |_____|wiper
onre wrote: Fri Feb 27, 2026 10:37 am If only these were audio taper! The project I had in mind was adding flying faders to my old analogue desk. Of course I could build a bank of 8 VCAs... so many ideas, so little time.
I cannot find the track value for those faders but you can convert lin to log (sort of) with "law distorting" resistors. Check out Duggie Self's book on small signal circuits.
If the track is say 10k the resultant resistance gets a bit low for some op amps but the NE5532 or better will have no problem.
