It looks like I need to revisit this topic every couple of months.
I had a pretty extraordinary jam this evening with the 245t and 257t, Buchla/TT dual VCO, Wiretap, and Pet Rock.
The core of the patch is taking lane A and B from the 245t and and patching them into Va and Vc on the 257t's upper processor. I then do the same for lanes C and D into the lower processor.
The voltage output gets patched through Wiretap and Wiretap's envelopes are triggered by Pet Rock, which is getting a multed clock pulse. Wiretap's through inputs are patched to a Doepfer dual quantizer.
The envelopes are patched to a low pass gate, Doepfer mixer, and finally a strymon aa.1.
This may be my favorite exploratory patch to date. As Vc is mixed with va, the range between notes shifts. The voltage output acts like a shift register.
The result is that I'm never quite sure what I will end up with, but it all sounds fab! There's something alluring about turning a dial, ending in a strange place, and not quite finding your way back. It's very "modular', I wouldn't know where to begin patching this in software or on a fixed architecture synth.
The quantizer keeps things musical to my ears, but someone more daring can easily forego it.
The Buchla modules are really something special if you're willing to go down the rabbit hole.
