New Soldering Iron
New Soldering Iron
Post by GRAHAM99 »
My old Weller iron has finally given up the ghost.
Any recommendations for a replacement?
Thanks!
GRAHAM99
Posts: 305 Joined: Fri Nov 15, 2002 12:00 am
Re: New Soldering Iron
Budget?
I’ve got a Hakko 888 that’s about 8 years old but the current version of it looks a bit different, maybe a bit simpler to use. Around £200 but it is a well respected brand.
Other brands are available.
Post by GRAHAM99 »
I want to spend up to £100 if possible.
GRAHAM99
Post by Albatross »
(I jsut saw your £100 post so the following doesn't apply but I'll leave it for people on a budget)
I just get the Draper ones from Halfords. Not the best but they do a 30w & 60w. They don't last forever but they are pretty good and cheap, always in stock and they fit in the Draper soldering kit box my wife bought me for a birthday. That was four years ago and I'm on my first replacement. I use it most weeks so not too bad. I'm no expert though so best listen to others.
Albatross
Posts: 3145 Joined: Sun Jul 26, 2015 12:00 am Location: Airstrip 1, Eurasia
I use one of these:
https://cpc.farnell.com/duratool/zd-931 ... 20stations
It's well under £100, even with a few different size spare bits.
Posts: 43704 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by ajay_m »
This is what I've had for many years,Maplin sold them. There are several different tips available for them on eBay.
https://cpc.farnell.com/duratool/d00675 ... I9ew9JeHxV
ajay_m
Posts: 1682 Joined: Mon Jan 16, 2017 7:08 pm
Post by GRAHAM99 »
I’ve got option anxiety now!
GRAHAM99
Post by nathanscribe »
I've been using one of these for years and it's never let me down. Plenty of tips available as well. I use a separate desoldering station and hot air station but this is my regular iron.
https://cpc.farnell.com/tenma/21-10115- ... %20station
nathanscribe
Posts: 1566 Joined: Fri Jan 19, 2007 12:00 am Location: Wakefield, for my sins.
Post by Tomás Mulcahy »
The Duratool is fine, but takes a while to heat up. I replaced mine with this and it is far better. Heats in seconds and has a much wider variety of tips. It’s a Hako knock off apparently.
Tomás Mulcahy
Post by Bob Bickerton »
OK, over budget, I bought this one: https://cpc.farnell.com/hakko/fx888dx-4 ... 20stations
Until then, I just used cheap irons from local retailers but I had a big job of way lines to install so bit the bullet. I never imagined I'd get warm fuzzies from a soldering iron (well, that is unless I dropped it in my lap without noticing), but it was something of a revelation to use something like this.
Not saying you need this, but a temperature controlled 'station' is highly recommended.
Bob Bickerton
Posts: 5642 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Post by ajay_m »
The main thing to watch out for is tip availability. The iron I recommend here has about five or six different tip profiles available and they are still widely available on a model that's been out for ages. Unless you're only doing one task, easily replaceable tips are vital. On this iron you just unscrew the collar and slide tips on and off, so you can switch from say a fine needle nose tip for chip soldering to a wedge tip for heavier work etc
ajay_m
Unless you do very little soldering and just pull an iron out to fix the odd cable once in a bluey, get a Hakko, best iron I ever used and I ran a Weller magnastat in various forms for 30 years+. The Hakko is even better.
If you really do only fix the odd XLR/TRS plug once every six months then the 30-50 quid stations are perfectly decent.
On Dave's suggestion I bought myself one of these when my old Oryx iron died
https://www.ebay.co.uk/itm/197852671141
The price has gone up since I bought mine but so far it has been fine. It takes a little time for the tip to properly warm up but that's similar to a traditional Weller iron. The cable is also maybe a bit stiffer than others but I don't find it a problem.
Posts: 16993 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by Nazard »
I've had a Xytronic for well over a decade, excellent with a wide selection of inexpensive bits.
This Xytronic from Rapid is excellent value, just under £100, and at 80W has that extra power for thicker cable, etc..
https://www.rapidonline.com/xytronic-lf ... on-85-6700
Nazard
Posts: 797 Joined: Sat May 15, 2010 12:00 am
Post by GRAHAM99 »
I have ordered the one Hugh recommended.
If it’s good enough for Hugh……!!
GRAHAM99
GRAHAM99 wrote: Fri Mar 06, 2026 12:16 pm I have ordered the one Hugh recommended.
Some of Hugh's work...
:o:shocked::shifty:
Post by onre »
Nazard wrote: Fri Mar 06, 2026 11:05 am I've had a Xytronic for well over a decade, excellent with a wide selection of inexpensive bits.
The choice has apparently been made already, but here's another vote for the Xytronic. I bought a 369 around 2010 and it has just worked ever since, so I ended up buying their soldering/desoldering station for the lab. That has also just worked. Interestingly, the soldering iron of that unit uses tips that are interchangeable with the Weller LT range.
onre
Posts: 4 Joined: Tue Mar 05, 2024 12:28 pm Location: Tampere, Finland
U = R * I -- It isn't just a good idea, it's the law.
Post by GRAHAM99 »
I think my new soldering iron is arriving tomorrow!
Should I set the temperature at about 330 centigrade?
GRAHAM99
It depends on the type of solder and whether you are soldering or desoldering. There are various lead-free formulas and some need it a bit hotter than average. And I find lead-free needs a higher temperature when desoldering.
So experiment with what you have to work with. Just hot enough to melt the solder within a second or so but not hotter than necessary. The smaller the tip, the more it cools down when applied, so you may need it a bit hotter when using a small pointy tip than a wider chisel tip.
