Should I loosen my electric guitar strings when not playing?
Firstly apologies if this is so stupid a question that you seasoned guitar folk are rolling about already, but, I have a few electrics (more than 1 and less than 6) which I play at least everyday. Now I have favourites so they don’t get played regularly everyday. They sit in the rack and sometimes may go for a few days without a play. But I do use them all.
Should I do anything different to just playing them and leaving them be?
I’ve avoided looking on the internet just in case it feeds my paranoia, but I’m sure you can all help.
So am I just fine leaving them tuned up ready to grab?
Thanks all in advance.
Ian
Ian
Re: Should I loosen my electric guitar strings when not playing?
Good question, but more importantly, try loosening them while you’re actually playing.
I suspect it may improve my solos!
Ian
- Music Wolf
Posts: 2894 Joined: Fri Feb 17, 2006 12:00 am
No One There
https://starbelly.bandmule.com/
I leave mine at tension, I feel the strings and truss rod are balanced against each other so why mess with it? But actually it probably makes little difference these days.
Life is wealth. (John Ruskin)
Phew, I've stopped rolling about now. That was hard work!
As Adrian said, the strings and the truss rod are balancing each other, so there's no point loosening the strings.
Too loose for a long period and you may find the neck doesn't go back to quite the same position when you tighten the strings, especially if there have been significant changes in relative humidity levels, requiring a truss rod tweak.
It's not the end of the world to do so, but if you just want to pick the guitar up and play, then that ten minutes spent finding a screwdriver and the right hex key or spanner then using it, can kill the mood.
I think Syd did that sometimes (while off his face on LSD) until they basically fell off... and it was one of the triggers for the rest of Floyd deciding not to pick him up for a gig (ever again)
Thanks chaps, I’d hoped you’d say that!
Ian
Ian
I have 8 guitars, all live tuned up to pitch in a rack and they have been like that for several years, some get played every day or two others don't get picked up from one month to the next but no harm has befallen them.
I’m not commenting how many I have ( opinions vary , some might say not enough. Others too many , it’s more than some people , not as many as others , ) Some don’t get played for months , one or two occasionally have a quiet year . But they’re all set up ready to go at a moments notice .
- Studio Support Gnome
Frequent Poster - Posts: 3025 Joined: Tue Jul 22, 2003 12:00 am Location: UK
Mostly Retired from Audio.... If I already know you I'll help, if not.... Ask Hugh Robjohns, unless that is you're in need of 80's shred guitar... that, I'm still interested in having fun with...
About 30 acoustics, electrics and basses. Almost all of them I can get out of their cases and they’ll be in tune (or only out very slightly but still good enough to play without bothering to tune them and not wince).
Yes, that’s why I didn’t really want to have to mess with them, I absolutely love just picking one up and, bang, there you are. I’m a pianist by training and that’s what you do with a piano, impulse/idea = play!
In my studio all my keyboards need to be switched on, computer on, select preset…….
And guitars just look so beautiful in a way a synth just doesn’t, (except a Minimoog naturally).
Ian
Thank you sir, I suddenly don’t feel so alone!
Doesn’t it get tiring 24/7 being surrounded by such beauty and inspiration?
I mean you must be writing non-stop!
- ManFromGlass
Longtime Poster - Posts: 7863 Joined: Sun Jul 24, 2011 12:00 am Location: O Canada
While guitars in a rack or display case look cool, humidity variations will always take its toll on them.
I always leave mine in their cases when not in use.
- Philbo King
Regular - Posts: 383 Joined: Thu Oct 11, 2018 10:07 pm
Wonks wrote: ↑Sat Mar 07, 2026 9:33 am I think Studio Support Gnome has a similar number.
Thereabouts but I didn’t want to frighten anyone
Bought a new acoustic in January sales , but have otherwise been restrained by lack of space .
Currently every single guitar is cased , rather than out on the racks like usual. , had to pack Up everything whilst building works for new boiler and hot water systems were underway .
Moving to larger , or differently organised house is a subject up for discussion here as well now For a number of reasons . Sadly , Guitar housing is only a fringe benefit . Office space is more important.
Working weekends as well , doing some acoustics consulting on the side , burning candles at both ends and in the middle , The usual nutjob schedule that makes playing guitar a tad tricky .
IAA wrote: ↑Fri Mar 06, 2026 6:59 am I have a few electrics (more than 1 and less than 6) which I play at least everyday. Now I have favourites so they don’t get played regularly everyday. They sit in the rack and sometimes may go for a few days without a play. But I do use them all.
Ian
So, to sum up, you have 5 electrics ("more than 1 and less than 6"), which you "play at least everyday."
However, "they don’t get played regularly everyday."
In fact, they "sometimes may go for a few days without a play."
Are you on drugs?
I meant, I play everyday, mostly my favourites (tele and a Les Paul) so some may go a few days without a twiddle.
Anyway, I’m happy to leave them be, they look great, and being able to pick up any is great. I’d just read an email that made me think I was being far too cavalier with them.
Ian
Re-loose strings.
I have an electric which is my experimental guitar, meaning I’m not afraid to change pickups, drill holes in it for adding or testing other hardware etc.
For the past few years I have kept it tuned down a fifth. (This is written pre-morning coffee so I mean I tuned the E strings down to a B with the others down the same amount - is that a fifth?)
I love playing it. Can you imagine how far I can bend the G string? Great fun! I am surprised at how it stays in tune after some serious bending. The intonation is good and I didn’t need to tweak the truss rod. Haven’t bought a baritone yet but I suspect I would like one.
- ManFromGlass
Only if you're alluding to a fifth of vodka...
I love your idea of having a guitar you can do violence to without caring: I tried decorating a Squier Strat with some bits and bobs, and I ended up snapping the pickup soldering.
Now it only makes a sound if I hit it with various objects. Still, beautiful plumage!
