Hi all. Currently in two bands, a three piece (occ a sax as well) which is electric drum kit and a four piece - mostly acoustic drum kit. I have a pair of RCF 312 tops and a studio spares 15 inch sub.
I like the tops and will still keep them as spares but they are pretty heavy (around 20kg each) and the sub is 38kg. All three heavy and very bulky and with my bass rig and lights means that I struggle on gigs in the ULEZ as I need to take the smaller car.
I’ve been thinking of updating for a while and initially thought of a column PA (x2) however I’ve moved away from that as the ones I would have EV50? are out of my budget.
So I’ve listened to a pair of RCF 910 and I have to say they sounded pretty good to my ears. In fact very good - way above my 312s. I was going to get the RCF 702 sub to go with them which would be a smaller lighter system in total and would sound good. We play pubs and smaller clubs so assuming they are as loud or louder than the setup I have (on paper they are louder) then they should be fine.
Anyone use these and could comment? Would the 10s on top with a 12 inch sub be ok? Would struggle to afford two subs.
I like RCF stuff in general - simple but quality. I did look at ALTO stuff - the TS410 plus a sub which is a lot less but I haven’t heard them and I’m not sure of the reliability. Yamaha DXR adds a fair amount more into the price. RCF seem to offer a good price/performance ratio.
RCF 910
Re: RCF 910
RCF I’m also on my second pair and my dad’s rcf made Mackies are still working perfect after 20 years.
They are top quality reliable speakers. The 9 series are superb get them.
- stevetrumpet
New here - Posts: 14 Joined: Thu Apr 09, 2020 4:57 pm
Re: RCF 910
RCF make good kit, those early SM450s made by RCF sounded much nicer than the later versions. 10" drivers usually sound better than 12"s in the vocal range. Alto's sound decent but you usually get what you pay for (I can't comment on reliability as I haven't used any since the TS1xx range which weren't). Yamaha's are very nice but even with a 7 year warrantee reliability is not assured as evidenced by the dead DXR10 in my garage. I haven't heard them but I'd expect you will be well served by the 910s.
Forum Aficionado - Posts: 22907 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Re: RCF 910
The Altos I've had have been reliable, and powerful.
That said, they don't touch the RCF for sound quality, and if you can afford the RCF, you're getting a much better speaker that you'll have to EQ less to get what you need out of it.
- Dave Rowles
Posts: 1589 Joined: Thu Feb 28, 2008 12:00 am
http://www.manninmusic.com Teacher - Isle of Man
http://www.manninmusic.shop Music Shop - Isle of Man
https://www.facebook.com/mannin.sound - PA Hire/Sound Engineer - Isle of Man
Re: RCF 910
Did listen to the Altos, not bad but I was so impressed with the RCF 910s, I ordered them instead. And the 702 sub. Arrived last Saturday and I have to say the sound is awesome! Really impressive vocal sound. Got eight gigs between now and the end of the year to put them to the test.
Re: RCF 910
Not surprised with the assessment! Altos are good for the money, but RCF, as you've discovered, are better!
- Dave Rowles
