Auto colour tracks by name- cubase
Post by gingertimmins »
Hi everyone, I would post this over at the cubase forum but everyone there is so busy reporting issues with 9.5 that I think I'll get a better response here.
In reaper I was able to have my tracks colour themselves automatically depending on what I called them. For example, I like guitars to be blue so any track with the name containing "Guit" would automatically turn blue.
Does anyone know if this is a feature in cubase? I'm running 9.5 elements if that's any help.
Thanks guys,
Chris
gingertimmins
Posts: 498 Joined: Wed Dec 05, 2007 12:00 am
Re: Auto colour tracks by name- cubase
Post by Mixedup »
It's not quite as easy to set up as in Reaper and not quite as versatile, but I believe it can be done — you need to get to grips with Cubase's Project Logical Editor — you choose 'filter targets' in the top section to which you want to apply results, and the actions (eg 'Set Color') in the bottom section. Whether you have that facility outside of Cubase Pro I can't recall off hand.
Mixedup
Mixedup wrote:It's not quite as easy to set up as in Reaper and not quite as versatile, but I believe it can be done — you need to get to grips with Cubase's Project Logical Editor — you choose 'filter targets' in the top section to which you want to apply results, and the actions (eg 'Set Color') in the bottom section. Whether you have that facility outside of Cubase Pro I can't recall off hand.
Great stuff, many thanks! I'll look into it over the next few days.
I've only just come back to cubase and I'm starting to realise just how user friendly reaper is. Cubase does however aid my creativity better which is the important part.
gingertimmins
P871 in the PDF manual.
Posts: 21238 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by Mixedup »
gingertimmins wrote:I've only just come back to cubase and I'm starting to realise just how user friendly reaper is.
I use both, on a pretty much daily basis. I think user-friendliness is to some extent in the eye of the beholder!
Mixedup
The Elf wrote:P871 in the PDF manual.
Thanks Elf but the elements PDF manual only goes to P673. What is the wording of what I am looking for?
gingertimmins
Ahh, scrap that, it's a pro only feature
gingertimmins
Post by Zukan »
Man, you're keen. I stopped at the index.
Zukan
Posts: 10131 Joined: Fri Sep 12, 2003 12:00 am
'Shaka. When the walls fell. Zukan...with his arms wide.'
1-2-1 Tuition
P871 is close to the end of the Index. Z for Zone
Posts: 13118 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Is it about a bicycle?
