Roland SH-101 questions
Re: Roland SH-101 questions
Post by Mike Craig »
A good friend of mine has just got his old SH101 out of the loft, he mentioned that a couple of pots aren't working correctly, so I will point him in the direction of this thread.
He also said that a couple of the white keys have been snapped off - does anyone know if replacement keys are available?
Many thanks,
Mike.
Mike Craig
Posts: 302 Joined: Sun Oct 05, 2003 12:00 am Location: Norwich (A Fine City)
Post by Kwaidan »
@ Scottishmick, try ebay uk, i got a couple of replacement keys for mine from a seller on there. He sells 101 spares including keys.
http://shop.ebay.co.uk/adam9816/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p4340
Kwaidan
Posts: 179 Joined: Thu Jun 26, 2003 12:00 am Location: UK
Kwaidan wrote: He sells 101 spares including keys.
Indeed he does!! Thanks Kwaidan!
Mike Craig
Post by Sam Inglis »
Update: I have been told by those in the know that it's probably a blown op-amp chip. Not sure if that's a repair that's within my powers...
Sam Inglis
Posts: 3228 Joined: Fri Dec 15, 2000 12:00 am
Hi Sam,
If you have a way of narrowing down which opamp then it’s not that difficult to replace one - often the trickiest part is getting the old one out.
Trying to remove an opamp as a single unit will probably do more bad than good with excessive temperatures on the circuit board.
Depending on its package design (and on a synth of that vintage I doubt that its will have too many ‘legs’) the easiest way is usually to snip all its ‘legs’ individually near the chip itself so that the chip bit falls off, and then you can use a desoldering device to remove each ‘leg’ separately and suck away the solder to leave a set of clean holes ready to drop in the replacement opamp.
Posts: 22574 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Thanks Martin,
Good thinking. If I can find a way to identify the faulty chip and find a suitable substitute, I'll have a go. My tame all-knowing SH-101 expert suggests the culprit might be one of the LM2209 op-amps, in which case there are only four legs each side to deal with. Any idea what might be a good modern alternative to that chip?
cheers
Sam
Sam Inglis
Post by forumuser695516 »
I was just looking here: www.vintageplanet.nl (a company i've used for old synth bits before). It doesn't list a LM2209 for the SH101, but does have a 9022 opamp. The same number, reversed?!
If that is what you need, then fortunately it is not pricey..
Paul
forumuser695516
Posts: 845 Joined: Wed Sep 01, 2004 12:00 am
d'oh. Yes of course I mean IR 9022
Sam Inglis
Sam Inglis wrote:d'oh. Yes of course I mean IR 9022
Ahh good :) In which case you won't need any modern substitute, as they are only 2 or 3 quid each from that company I mentioned. I expect the postage will amount to more than the part itself though. That said, I think there is more than 1 in there? I don't know if you wanted to change all of them to be safe, or track down which is at fault first?
It wouldn't hurt to check continuity of those jumper/ribbon cables while you are in there too, as they break pretty easily.
Paul
PS, scottishmick . The above company also seems to have stock of those white key caps too. Not so cheap though!
forumuser695516
Vintage Planet's minimum order is 15 Euros plus postage, which I guess is OK, but if I can nip down to Maplin and pick up something suitable for 50p it would be easier.
I guess it's academic anyway, until I can figure out for certain which chip is at fault.
Sam Inglis
Post by DragonLogos »
Richie Royale wrote:WD40 is for water displacement and not really recommended for contact cleaning. Caig's De Oxit or other similar cleaners are recommended.
is this a personnel expereance, have you tested WD20 for contact cleaning properties for some period of time?
DragonLogos
Posts: 263 Joined: Mon Oct 14, 2002 12:00 am Location: East London
WD40 is not, and never has been, a contact cleaner. But because it happened to work well at expelling water from vehicle HT electrics people who didn't know better promoted it as a contact cleaner. You will notice the there is no mention of contact cleaner on the can ;)
Posts: 13295 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
WD40 is useful for "drying out" electrical systems where moisture is present. This can help to remove any short-circuits caused by the moisture bridging the gap between bare electrical contacts. This makes it ideal for maintenance to vehicle electrical systems, where moisture is a problem. WD40 also helps to remove any covering of rust from bare metal parts (effectively washing it away).
Deoxidising/Deoxidizing solutions, such as Deoxit, chemically dissolve the surface corrosion, leaving a clean metal surface (good conductor) without oxide debris, which is what you need within your pots/sliders on your Synthesizer. :)
Mike Craig
zenguitar wrote:WD40 is not, and never has been, a contact cleaner. But because it happened to work well at expelling water from vehicle HT electrics people who didn't know better promoted it as a contact cleaner. You will notice the there is no mention of contact cleaner on the can ;)
Is this a personnel expereance, have you tested WD40 for contact cleaning properties for some period of time?
Now the reason that this question has been put forward is that in 1979 the reps for WD40 asked me to try out their product in my workshop, giving me a very broad base on what it would work on... four big cans of the stuff were purchased so it could be used and evaluated as the need would arise.
There are a few things that can be said about contact cleaners, like tuner cleaners and such, but as far as general contact cleaners go WD40 is fine and you are all welcome to cast the first stone if it is otherwise
DragonLogos
To be fair, I haven't run personal long term tests. To some extent I am repeating the information given to me others far better qualified than I am, my amp tech and a handful of ex Royal Navy & merchant navy electricians among them. But that doesn't detract from my main point, the manufacturers make no claim for WD40 to be a contact cleaner beyond automotive use.
I am more than happy to be proved wrong, because WD40 is easy to find and cheaper than more specialist cleaners.
