Wonks wrote:If used as a limiter, with a threshold set so that the speakers can go loud but not over loud, then it should certainly help a lot. Don't add any make-up gain! But if there is a source of high or ultrasonic noise/distortion somewhere in the system, then there could still be a lot of HF energy getting through, more than the tweeter can cope with, then you may have to lower the limiter level even more. It's very unlikely, but it is theoretically possible.
where do you reckon i should set the peak stop limiter level on the DBX 116XS
PEAKSTOP LEVEL Control and LED
This control allows you to set the maximum peak output level of the 166xs regardless of any
other control. PeakStop comes after the compression, gating and output gain circuitry; this
provides for an absolute limit to be put on the peak excursions at the output. PeakStop works
instantaneously; you can apply moderate amounts of dbx’s OverEasy compression and still be
protected from large transients, other short-term overloads and overmodulation.
PeakStop is a smooth well-controlled soft clipper whose behavior is sonically similar to the
gentleness of OverEasy compression; its clipping is much preferable to a power amp’s or
analog-to-digital converter’s. PeakStop rounds the corners of a peak rather than cutting it off
sharply. By making a signal’s leading and trailing edges curved instead of sharply angled, it
reduces the amount of higher odd-order, offensive-sounding harmonics that conventional hard
clipping causes.
The level at which PEAKSTOP is activated is adjustable from +0dBu to +20dBu. Note that small
signal excursions above the set value of PEAKSTOP are possible, to allow the rounding to
occur. Therefore, for applications where you must not exceed a given ceiling, set the
PEAKSTOP control 1dB to 2dB below the ceiling.
The PEAKSTOP LED illuminates whenever peaks attempt to exceed PeakStop level and are
reduced in amplitude. If the PeakStop LED illuminates when the PEAKSTOP LEVEL control is set
to +20dBu, the headroom capabilities of the 166xs are being exceeded and hard clipping is
occurring.
