Anything cheaper than iZotope's RX?
Re: Anything cheaper than iZotopes RX?
Post by Mixedup »
TNGator wrote:It's just this one particular project
Use the iZotope demo? I can't recall what the limitations are, but typically you can render results from these things in one way or another.
Or if it really is just the one project, why not invite someone else to do it for you and avoid spending all that time learning to get the best results from whatever tool you purchase? :headbang:
Mixedup
Post by ken long »
Tim Gillett wrote: Really to advise with more certainty we need to hear the "pops and crackles" that you are hearing. There are limits to what's possible without damaging the wanted audio. Any chance of a short sample audio?
I agree with Tim. Are these pops and clicks convertor sync issues?
Any spectral editor and some elbow grease will work better than a blanket noise removal plugin.
ken long
Posts: 3631 Joined: Mon Jan 21, 2008 12:00 am Location: Somers Town
I'm All Ears.
Post by TNGator »
Zukan wrote:Acon Digital might be worth a look. Cheap as chips.
https://acondigital.com/products/restoration-suite/
Thanks guy..I'll go have a look.
TNGator
Posts: 192 Joined: Wed Mar 20, 2019 10:55 pm
Southern kin y'all
Post by TNGator »
Tim Gillett wrote:
TNGator wrote:Hey gang. Im plagued on this song with pops and crackles on various tracks. Not extremely loud but they are there. I tried Audacity and it did nothing. I know iZotope software is really good and i have one or two items of theirs. But even the RX7 elements is like $130. Anyone know of a good software fro removing unwanted pops and such? Thanks y'all.
Tim
Hi Tim. I'll see if i can put even one track maybe on soundcloud and share the link.
TNGator
Southern kin y'all
Post by TNGator »
Hi Ken. What is a spectral editor please? perhaps if i can explain more clearly. Let me go through the tracks and find exactly which ones have the crackles. Some tracks were recorded by mic such as vocals and a fender strat. Some were done by DI such as the bass. Im very careful about gain staging and dont record hot at all. In fact the level is quite low. let me see what exactly what is popping and how it was recorded. In the meantime I'll continue searching for a good software tool for this.
TNGator
Southern kin y'all
Post by Mike Stranks »
This is a quick demo of what you can do with spectral editing:
https://www.youtube.com/watch?v=PKTcC9bqlS0
Posts: 10589 Joined: Fri Jan 03, 2003 12:00 am
Post by TNGator »
I dont know anyone Mixed. But thats ok.. I always get great help and feedback on the SOS forum so I'll manage somehow :thumbup:
TNGator
Southern kin y'all
Post by TNGator »
Tim
Tim / Ken. I might have to run away and quit the SOS forum due to embarrassment and wasting everyone's time.. Your question re what kind of noise am i getting got me to export a track to the demo version of RX. There was no noise to be heard in RX but it was clear in my DAW. I then played a few of the tracks in Windows Media player. No sign of any clicks etc either. When i went into Cakewalks settings I saw that the number of buffers in playback was only 2 and it was grayed out. I went into windows control panel and there is a panel there for my M Audio. When i raised the latency fader and went back into the DAW it seemed to play without the pops and such. It might have been a buffer setting causing this. I'll keep testing but this is starting to look like an embarrassing goof on my part.
TNGator
Southern kin y'all
We've all been there!
Yup, even the good guys, in my case it's a daily occurrence....... :headbang:
Posts: 22901 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
The tales I could tell from the last 50 years! :oops:
Just a few weeks ago I was asked to run a small sound system for a local village fete. Two radio mics and background music. Simples.
Set-up was fine and all power-lights lit up as expected. Tested mics all fine. Music feed from PC - zilch.
USB lead duff? Change lead: nothing. USB socket gone funny? Different socket: nothing. Laptop got its knickers in a twist? Full reboot: nothing.
Then I turned up the channel gain and all was well.... :oops::headbang::oops::headbang:
Post by BillB »
TNGator wrote: I'll keep testing but this is starting to look like an embarrassing goof on my part.
The important thing is that a) you found the problem and b) you shared the solution. That way we all get to learn something, including about cheaper alternatives to RX :D
Plus we get Mike’s priceless tale.
Glad you got it sorted.
BillB
Don't think there's any need for embarrassment. We've all been caught out by cunningly hidden settings! But it does sound very likely that the clicks were indeed due to the buffer being too small to sustain glitch-free playback. Glad it was an easy fix!
Posts: 43685 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by Kwackman »
BillB wrote:The important thing is that a) you found the problem and b) you shared the solution. That way we all get to learn something.
+1. :thumbup:
Kwackman
Posts: 3686 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Re: Anything cheaper than iZotope's RX?
Post by Mixedup »
Cool. Problem solved at source = best possible outcome! :headbang:
Mixedup
Post by ken long »
OK - seems as though you're talking about noise in the signal rather than any clicks from syncing your convertor.
Many editors have a spectrum view that will allow you to surgically remove the clicks much like photoshop. Izotope has this but so does Wavelab and SADiE. There's also Sony's Spectral Layers etc. Not sure which is the cheapest or which one would provide you with value for money if it's a one-off repair.
ken long
I'm All Ears.
Post by Mixedup »
ken long wrote:Many editors have a spectrum view that will allow you to surgically remove the clicks much like photoshop.
Yes, there are many spectral editing tools now but they're not all created equal. I believe only CEDAR and iZotope can intelligently fill the gaps left behind by your spectral edits by interpolation, in the same way that Photoshop can when, for example, removing a telegraph pole from a pic. The others just allow you to remove/manipulate the existing data and perhaps apply crossfades with the adjacent bits
Mixedup
Post by ken long »
Well not really. Wavelab is very good at this too (I use it everyday for such tasks). And as I mentioned, Sony Spectral layers takes it a step further with the ability to reveal layers behind layers. There's quite a few options on the market now.
https://www.youtube.com/watch?v=juD6KKrM0Bs
Glad to hear it was a buffer issue. Makes it much easier to deal with ;)
ken long
I'm All Ears.
Post by Mixedup »
ken long wrote:Well not really. Wavelab is very good at this too (I use it everyday for such tasks). And as I mentioned, Sony Spectral layers takes it a step further with the ability to reveal layers behind layers. There's quite a few options on the market now.
Yes, really.
For all their other strengths — which I agree are many — neither Wavelab's spectral editing nor Spectralayers generates new background sound based on analysis of the surrounding material to fill the blanks when removing unwanted noises. Nor do the various others, except RX and CEDAR's software. If they did, without CEDAR's permission, I imagine CEDAR would litigate to enforce their patent; they've done so successfully before...
Mixedup
Post by ken long »
Yes, really.
I guess I missed the bit where you wrote "intelligently". Wavelab is probably a little behind in this respect as it's still a bit of a manual task. But you can still analyse the surrounding areas. It's just not as automatic.
ken long
I'm All Ears.
Post by TNGator »
All in all...there seem to be a few software packages out there that can do this sort of cleaning. Although it seems i got out of jail on this occasion, it would do no harm to have this sort of toll in the toolkit going forward. Although expensive, it seems a lot of folks here have mentioned the iZotope software (and Cedar too). As an existing iZotope user i'll touch base with them and keep an eye out for deals for existing customers.
TNGator
Southern kin y'all
Mixedup wrote:neither Wavelab's spectral editing nor Spectralayers generates new background sound based on analysis of the surrounding material to fill the blanks when removing unwanted noises. Nor do the various others, except RX and CEDAR's software. If they did, without CEDAR's permission, I imagine CEDAR would litigate to enforce their patent; they've done so successfully before...
Unless I'm using RX's spectral repair in the wrong way I don't see it as being particularly intelligent. If I'm removing clicks then I find Audition's 'Fix single click' to work far better than attempting the same thing in RX. If there is a transient close to the click then RX has a habit of removing the transient - even though it is outside the selected area - which sounds very odd. Unfortunately my version of Audition only repairs clicks in this way so it can't be used as a general spectral repair tool.
Posts: 16984 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by TNGator »
Hugh Robjohns wrote:Don't think there's any need for embarrassment. We've all been caught out by cunningly hidden settings! But it does sound very likely that the clicks were indeed due to the buffer being too small to sustain glitch-free playback. Glad it was an easy fix!
Thanks Hugh. Nice to get friendly support even you screw up :)
TNGator
Southern kin y'all
Post by TNGator »
Mixedup wrote:Cool. Problem solved at source = best possible outcome! :headbang:
yep...hammer over the head...thats how I feel LOL :headbang:
TNGator
Southern kin y'all
Post by TNGator »
Thanks for the support Bill. Nice to to be able make goofy mistakes and come clean and not get laughed. Some forums out get some really nasty smart remarks. Thanks again all for the tips and help :)
TNGator
Southern kin y'all
