CS70 wrote: On the technical side, if the noise is loud enough to annoy you, it's odd that it cannot be captured by a mic, unless it's really, really low frequencies (which you would perceive more as a vibration than a sound).
Nuisance noise, according to the EHO I had the conversation with, does not need to be loud, or even above the ambient noise, it simply has to be audible. The almost imperceptible but rhythmic 'thump' of the bass from the DJ in the marquee ½ a mile away was enough for him to say it was too loud. Even very quiet door closings or footsteps can be intrusive late at night but if it is just people conducting their normal lives in a flat where sound travels between floors that is clearly a different matter to people playing loud music or having shouting matches in the early hours. Context is everything
And almost certainly is not the preamp noise floor of the Zoom which is the problem, and what you are hearing is the ambient noise in you room.
Yes, probably.
But might it be that it's more of a perceptive issue, like you're trying to concentrate and suddenly there is a relatively faint but audible door slam which annoys you? Or do you hear it really loud? Because if you do, so it will even the cheapest microphone.
Yes, see above.
More detail would be useful Doveman please tell us what it is that disturbed you and what times of day/night it occurs. And, as I said above, keep detailed records, they will be much more useful in a court of law than uncalibrated noise meter readings or recording that demonstrate the 'nuisance noise' is below the ambient.....
