cubase not fully panning
Re: cubase not fully panning
Please if you can, load up Pro Tools and see if you can replicate this anomaly!
I have Pro Tools but bought Cubase to switch, as I'm on pt10, but I'm dragging my ass on switching. I just don't wanna do it and take years to learn this new software inside and out! Hell I tired Studio One and couldn't figure out how to just get to the mix window and edit window! I ended up giving up!...hahaha
Anyway I'm very curious if it's a Cubase bug or if it's your Focusright interface possibly, or just some weird setting that you mightve missed. Stuff like that always happens to me, I'll be rushing and I'll forget something and BOOM! Slapping my head like Doh~!
You just never know with this new gear coming out!
- LoveMonkey3833
- Posts: 3 Joined: Tue Sep 26, 2017 9:25 am
If it's any help, Kwackman did the tempo map for me. He'll maybe have my file
- MadManDan
Frequent Poster - Posts: 601 Joined: Mon Sep 13, 2004 12:00 am Location: Across the pond....New Yawk
Late '14 mini 3 GHz i7 16 GB
Catalina 10.15.7. Glyph atomic. FF Scarlet 18i8.
Sup Drum 3. Cubase 11 Pro
iCon iKb 8x. Mics, spkrs, 'phones, gtrs, greedy cat
MadManDan wrote:If it's any help, Kwackman did the tempo map for me. He'll maybe have my file
Ah, didn't realise it was the same project. I'll have a play later....
Dan,
I've had a quick look, obviously I'm using a different interface but the main stereo routing should still be OK.
Panning seems OK here, I'll try again to be sure.
But what I did find were several channels that were hidden on the mixer using the "visibility" options. 3 of these had the little speaker icon turned on, so they are listening to whatever input is plugged to them.
Try un-hiding all your mixer channels and turn those speaker icons off...
The tracks with the speaker icon turned on are called "orig CD" "cd L" and "cd R"
LoveMonkey3833 wrote:Please if you can, load up Pro Tools and see if you can replicate this anomaly!
In December I started a thread about my dissatisfaction with midi in pro tools, and eventually people here were raving so much about cubase that I had to try it.
Maybe it's like this with you, you get comfortable with a routine, like pro tools, and it's hard to switch. But for me the time had come.... the "joy/expense" ratio was just not cutting it anymore.
Beyond only basic midi capabilities, I really didn't like how pro tools had this nickle and dime control. I hadn't the $600 to buy it outright, so ended up spending $30/mo for yearly licence. All that was tolerable, I dealt with sub par midi. But then they gave this whole suite of amazing, usable plug-ins that would soon have me depending on them.
Problem is, if you miss one payment on the yearly sub, you lose these plug ins forever once you resume payment. THAT DID IT FOR ME! I WAS OOOUUUTTTT !!!
Yes, cubase artist costs $300. But the midi is amazing, and there are tons of gorgeous plugins. Much better "joy/expense" ratio
I was packing up all my pro tools audio and midi files for xfer to cubase, and was planning on pulling the plug in April. I hadn't even considered the fact that one cannot just ummm cancel a yearly contract mid-stream
Then corona hit. Have to watch the wallet. So I contacted Avid, who said no problem, you're cancelled. So now my only PT is that free one.
Getting back to my tech issue
- MadManDan
Back again.
Panning OK here. I panned the music track to the left, unplugged the input to the left speaker - nothing leaking out of the right speaker.
Then panned it to the right, unplugged the right speaker and the left was totally silent (and I did plug it in again)
The track "orig CD" is REALLY LOUD. there's 24 dB gain added to the clip, but you've turned the fader on the mixer down to minus 24dB? You've used automation and towards the end the fader moves from -24 dB up to +6dB!! That's incredibly loud! So, there might be a gain structure issue?
EDIT. in my previous post I said you had hidden channels in the mixer. The visibility options are also on the main project window, so you might have hidden them there, then the mixer echo'ed your visibility choices? Anyhow- have a look at your hidden tracks/channels however you did it!
2nd EDIT! If none of the above change your problem I suspect it's not in Cubase, but your interface SW?
Hi all.
I created this file, “beep”, to demonstrate. All that I did was
Created a new session, imported a mono file, “beep mono”
Panned it to the left.
Exported it as a stereo file, “stereo export” and
Exported “split mono export” (left and right)
Check out the exports. Playing the stereo export, I hear a bit of the leakage on the right.
Please let me know how this comes up for y’all
Thanks, MadManDan
https://drive.google.com/open?id=1V-pjN ... BN3jFzzrQt
edit: Just recreated this with pro tools "First" Not the rendering part, just the loading the beep and panning it left. Yeah, this is something my focusrite must be doing. I hear it on pro tools too
Thanks, MadManDan
- MadManDan
All silent on the right here, as I think we all expected!
Your interface/monitoring chain has an issue somewhere. Did you say you've check all cabling? I don't recall you telling us what you are monitoring on, either. Sorry if I missed that.
- innerchord
Regular - Posts: 212 Joined: Wed May 11, 2016 12:00 am
So, it looks like my verbose comments about hidden tracks containing clips with 24dB of gain were all red herrings! I must exercise the "no typing after red wine" rule more strictly!
Hope you get it sorted Dan.
Kwackman wrote:So, it looks like my verbose comments about hidden tracks containing clips with 24dB of gain were all red herrings! I must exercise the "no typing after red wine" rule more strictly!
No problem. The website lost my response to your comment anyway
OK I'm right embarrassed. Found the problem. Both of my pairs of headphones. In my defense, I'm going nuts here in quarantine
- MadManDan
The Elf wrote:These questionable 'make my headphones sound like speakers' processors would have this effect.
Yes, especially the ones with dry signals and no effect sends
- MadManDan
