dBFS vs LUFS Loudness ???
Re: dBFS vs LUFS Loudness ???
Post by DigitalMusicProduction »
blinddrew wrote:I think the OP means he's going to be doing his own 'mastering' - in this case a bit of levelling really - in which case, once he's done the mixing he can just raise the level to his target.
That's correct, the project being worked on is a solo Piano album intended as a commercial recording for digital distribution and online streaming, no heavy processing or effects involved, maybe some EQ at the most.
To summarise then, floating at around -15dBFS to -20dBFS with no peaks any higher then -6dBFS is best recommended for a clean signal recording and streaming services?
Posts: 241 Joined: Thu Oct 22, 2020 7:00 pm
Music is a universal language that speaks to every person, a euphoria of moods that inspires, convicts and heals
DigitalMusicProduction wrote:To summarise then, floating at around -15dBFS to -20dBFS with no peaks any higher then -6dBFS is best recommended for a clean signal recording...
Correct.
And then, as a separate stage in creating your album, you can 'master' those individual recordings to make them compliant with the specs for the streaming services.
That means using one of the Loudness metering tools to assess the Integrated Loudness of value of each track and the True Peak level. Some tools require playing the track in real time, others can do it as an off-line process by analysing the file.
Once you have the numbers for your raw track you can assess how they compare to the target loudness specified by the streaming service, and raise/lower the track level as necessary. If raising the level you may need to introduce some brickwall limiting so ensure the transient peaks don't exceed the maximum True Peak value allowed by the streaming service.
Alternatively, you could just upload your raw recorded tracks and let the streaming service do any processing required automatically.... However, although all services will turn excessively loud tracks down, not all will raise the level for tracks with an Integrated Loudness value below the target. So it's generally best to correct the tracks yourself so that you know it's as good as it can be.
The Loudness penalty website is a really great site where you can drag and drop your track, and it will analyse and tell you what different streaming services will make of it.
https://www.loudnesspenalty.com/
Last edited by Hugh Robjohns on Tue Jan 26, 2021 11:18 am, edited 1 time in total.
Posts: 43685 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Thanks to everyone for all your support on this post, helpful.
