multiple vocals and only 2 channels compression
Re: multiple vocals and only 2 channels compression
Post by Bob Bickerton »
I've been fortunate in that most of the work I've done over the years has been festivals and concerts, so one off shows for the most part. The few tours I've done (as an audio engineer) haven't been prolonged enough for the ear-worms to dig too deep, and I've very much enjoyed the music which really helps.
But musicals are a different story. Again not too long a season two weeks plus a week of (tech/dress) rehearsals, but even then I found it really hard to get the Les Mis tunes out of my head. I countered them by listening to alternative music - a sonic flush if you will.
Oddly enough, several months after being 'cured', someone was walking down our valley whistling a tune from Les Mis - and the ear-worm awoke and everything came rushing back!
Bob Bickerton
Posts: 5641 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Post by Mike Stranks »
I guess it's to do with the environment/time/circumstances in which I come from - 50+years, mainly amateur, non-paid, limited access to any sort of outboard (or inboard!) - but I've always been a hands/fingers constantly moving kind of mixer. It's only in latter years that I've used any sort of compression on voice and, even then, with the lightest of touches on 'problem' singers/speakers.
As one would expect, Bob is spot on the money.
Posts: 10589 Joined: Fri Jan 03, 2003 12:00 am
Post by Luke W »
Bob Bickerton wrote: Sat Jan 29, 2022 1:00 am It needs to be said that compression can also be your enemy as well as your friend with a pile of open headset mics on stage - feedback is just stage left waiting to enter.
This is a good point, and if you do end up using some it's where being sensible with settings will be a huge help.
Bob Bickerton wrote: Sat Jan 29, 2022 1:00 am I've been fortunate to have done a few musicals with digital desks, which is great because you can programme scenes enabling channels too be muted, attenuated, or reinforced as per a solo - however even then you're always working hard to mix the show.
I'll admit, I'm a little spoiled here and I've only ever done one MT show on an analogue desk, and it wasn't an experience that I'm in a rush to repeat! Although the material has a huge part to play here, less busy numbers are far easier to manage than those with lines coming from here there and everywhere in quick succession.
Bob Bickerton wrote: Sat Jan 29, 2022 1:00 am So there's no avoiding it you'll be busy mixing, muting mics when offstage (unless you want toilet flushes and expletives). By all means use some subtle compression if it helps, but don't feel bound to it.
Absolutely, and even when people are on stage you'll want to be taking out mics whilst they're not singing or delivering lines. Even with a fairly modest channel count you can end up with a phasey mess pretty quickly. And lots of puffing and panting from people getting their breath back :lol:
Bob Bickerton wrote: Sat Jan 29, 2022 1:00 am Down side is that it can takes months to get the tunes out of your head!
And there it is, the biggest problem of them all. :thumbup:
Luke W
Posts: 1698 Joined: Thu Feb 19, 2009 12:00 am Location: Northamptonshire, UK
Post by SteveKD »
Thanks for all the comments so far, any other hints and tips appreciated.
I've done a few musicals now, but always with my own equipment. For this one I'll be using what already happens to be there. Luckily (for me) its an analogue desk, I don't think I'd have time to learn a digital one.
For all the past shows I've done I've always worked from a copy of the vocal score with mic numbers written in and warnings of when a level might need to be higher/lower than usual for a certain phrase.
What are peoples thoughts on reverb/delay? Would it be odd if some characters have more or less reverb than others?
SteveKD
Posts: 17 Joined: Thu Feb 11, 2021 10:14 pm
Post by Dave Rowles »
What desk is it? Just curious, as if you've to access to groups you might be able to use the compressors you have as buss compressors which might help you greatly. You'll still need to fader ride at bit, but it'll give you a fall back.
Dave Rowles
Posts: 1589 Joined: Thu Feb 28, 2008 12:00 am Location: Isle of Man
http://www.manninmusic.com Teacher - Isle of Man
http://www.manninmusic.shop Music Shop - Isle of Man
https://www.facebook.com/mannin.sound - PA Hire/Sound Engineer - Isle of Man
SteveKD wrote: Sat Jan 29, 2022 2:10 pmWhat are peoples thoughts on reverb/delay? Would it be odd if some characters have more or less reverb than others?
Reverb - Somewhat room and show dependent. If it's a dry room, then yes you may wish to place the voices into a more generous space, but I'd be very careful. It could enhance sung parts, but you probably wouldn't want it on dialogue, which means an extra layer of muting to contend with.
If used on sung parts, then I'd use the same level on all voices as the purpose is to try to 'improve' the acoustic of the room. But as I said, it's also very much show dependent and to do with how much you want to 'produce' a particular song.
Delay - I wouldn't touch it unless is specifically noted in the score or prescribed by the director.
Bob Bickerton
Post by Mike Monte »
:round1:
For the local high school shows that I have done lav mics I have made a list of the scenes (check with the lighting guy/gal for scene info) on which I note the channel numbers that need to be un-muted for that scene.
I will also tweak each scene a bit as some actors start their lines off-stage as they are entering.
It is funny that you mentioned working from a vocal score - I am doing a show in two weeks at a local prep school. (I have done this school's show for the past 20+ years - with the first ten years as a musician in the pit and thereafter as a musician mixing the music end of the production.) On this show I sit at FOH with the main job to "mic the pit musicians" (which is in another room of the building) and provide the mix in the monitors (for the cast) and also the house. I read the conductor's score as the show is going on and mix/balance the pit with the actors/actresses.
I also advise the guy who is doing the stage mics/lavs on balancing the harmony on the two/three/four part choral numbers as the melody is not always in the highest voice part.
Mike Monte
Posts: 119 Joined: Sun Apr 03, 2016 12:00 am
In the small number of productions I've done, I always get a copy of the script and mark up the script. Then it's a case of following the script just like I would sheet music. I also label the mics by part, though that supposes that there isn't a lot of mic swapping going on.
I tend to not do musicals/theatre for that reason as I find following the script tedious and boring after the first 2/3 performances. It's just a numbers game! :P
Dave Rowles
I haven't done any musical theatre for many years but, on the few shows that I did, my life would have been made far easier with mute automation as most of the work was muting and unmuting mics at the appropriate time.
Posts: 16990 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
This is where digital really comes into its own. Rather than a hard mute, I used to programme faders to zero with two benefits; Firstly, a hard mute can sometimes be noticeable relative to a quick fade, and secondly it's much easier to see which channels are live!
I'm very pleased I no longer do live sound!
Bob Bickerton
I mixed my only musical on an analogue desk so didn't have the option to do funky stuff like that, it was physical mutes (no mute groups) and faders... I vowed that if I ever did another I'd use a digital desk... That said I'm thankful in many ways that another hasn't come along, it was the most stressful gig of my (fairly undistinguished) career.
Posts: 22908 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
