A Newbie Asks About Omni Microphones
Re: A Newbie Asks About Omni Microphones
Post by Aled Hughes »
Hugh Robjohns wrote: Thu Feb 24, 2022 12:49 pm The Acoustic Pressure Equaliser -- APE -- or the sphere/ball attachment for some omni mics modifies both the frequency and polar responses, with the aim of enhancing on-axis clarity and subduing the off-axis ambience.
It does add brightness to on-axis sources through a pressure build-up effect but, more importantly, it also alters the direct/reverberation ratio, reducing the level of high frequency sound arriving off-axis. This is used, essentially, to give better stereo imaging in reverberant spaces.
Increasing the size of the sphere results in the effect working down to a lower frequency (and vice versa). Most sphere's are about 40mm, but they can range from 30-50mm.
It does a completely different thing to diffuse-field equalisation which is intended to ensure equal sensitivity and frequency response for both on and off-axis sounds.
EQ will obviously affect both on-axis and off-axis sources equally.
In contrast the near-field/diffuse-field equalisation is intended to compensate for a physical effect that occurs only with close on-axis sources.
In practice, you can boost the HF of a direct-field omni (flat for close on-axis sources) when used in the diffuse-field to restore a reasonably natural spectral balance.
Going the other way, cutting the HF of a diffuse-field omni to restore the tonal balance of a close on-axis source will also result in any off-axis spill sounding duller. Whether that's an issue depends on the circumstances, of course. A better option in this situation is simply to orient the mic so that sound from the wanted close source arrives side-on to the capsule (at 90 degrees) since this doesn't result in an on-axis pressure build-up and thus no HF peak!
Thanks Hugh.
I’ve always found my OM1s to respond well to a hefty EQ boost when placed in the diffuse field.
Aled Hughes
Posts: 1980 Joined: Tue Oct 24, 2006 12:00 am Location: Pwllheli, Cymru
Post by Mike Stranks »
So maybe that's the answer for me... bearing in mind my financial situation, the fact I already have OM1s and the relative (now) infrequency with which I'm recording in the diffuse field... some judicious enhancement in post...
Thanks all for comments and suggestions.
Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Thinking some more about this, and struggling to get my head around a couple of things.
Wouldn’t the net effect of
Hugh Robjohns wrote: Thu Feb 24, 2022 12:49 pm The Acoustic Pressure Equaliser… does add brightness to on-axis sources through a pressure build-up effect but, more importantly, it also alters the direct/reverberation ratio, reducing the level of high frequency sound arriving off-axis.
be very similar to the HF boost built into mics such as the KM183, which must be a directional boost seeing that the mics do not exhibit it at 90 degrees?
IE, wouldn’t the KM183 and a Line Audio with APEs both show increased sensitivity to on-axis HF, and by extension therefore have attenuated off-axis HF response?
On the same point, this:
…diffuse-field equalisation which is intended to ensure equal sensitivity and frequency response for both on and off-axis sounds.
seems to me to contradict this: (regarding sources arriving 90 degree off axis)
doesn’t result in an on-axis pressure build-up and thus no HF peak!
I think I’m missing or ignoring something fundamental here…
Aled Hughes
Aled Hughes wrote: Thu Feb 24, 2022 10:10 pm...be very similar to the HF boost built into mics such as the KM183, which must be a directional boost seeing that the mics do not exhibit it at 90 degrees?
If APEs did the same thing there'd be no need for diffuse field omnis.
The diffuse field omni is designed to capture sounds from all directions, in a diffuse field, with a equal level and a flat overall frequency response.
An APE is designed to narrow the polar pattern -- so not equal sensitivity to all directions -- as well as introduce a slight HF boost for on-axis sources -- so not a flat overall response in the diffuse field either!
I suspect it's that omni mics behave differently when close to the source, and when distant in a reverberant space. And so they are engineered to work correctly on one or other situation.
APEs do a different thing again...
Posts: 41727 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Thanks Hugh, that’ll be it!
So the 90 degree placement ‘trick’ only works for close sources? It would make no difference whether the mics were pointing forward or upward in the diffuse field?
Aled Hughes
Aled Hughes wrote: Fri Feb 25, 2022 11:41 am So the 90 degree placement ‘trick’ only works for close sources?
Correct.
Correct again. :D
:bouncy: There, that’s firmly lodged!
Thanks again
Aled Hughes
Post by jimjazzdad »
A short tale of diffuse and near field omnis with EQ: I made a cock-up on a location recording of a violin and piano. I accidentally mixed a Schoeps MK2 capsule with a MK2H capsule in the main stereo pair (I put it down to eyesight, but maybe I am doddering too). I didn't notice anything wrong monitoring on location with cans but when I got back to the studio... Anyway, I compared the FR plots for both capsules and created an EQ curve in my DAW to boost the HF on the MK2 to make it sound like a MK2H. No one - not the producer nor the musicians - ever noticed. (I should mention that there were spot mics to help the main pair, but even soloed, the mismatched mains sounded fine after EQing)
jimjazzdad
Posts: 286 Joined: Sun Dec 15, 2013 12:00 am
Halifax, NS, CANADA
This is where having microphones with good off-axis response helps I think. :)
Posts: 27698 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by Ariosto »
Hugh Robjohns wrote: Fri Feb 25, 2022 11:44 am
Correct.
I record a grand piano with two DPA 2006C omni mics (which are diffuse field) in the upright position very close to the strings with open lid, and this works very well. So I can recommend this technique - which I originally heard of from Hugh - some time ago.
Ariosto
Posts: 920 Joined: Sun May 04, 2008 12:00 am Location: LONDON, UK
Post by Sam Inglis »
MBHO / Haun in Germany make good modular small-diaphragm mics that are more affordable than Schoeps etc, and have a diffuse-field omni capsule in the range.
Sam Inglis
Posts: 3145 Joined: Fri Dec 15, 2000 12:00 am
Thanks Sam! :thumbup:
Aha! :D
I've just found these for the OM1:
https://www.shapeways.com/product/5KY2M ... -audio-om1
So I think I'll stick with the OM1s - far too much 'Seller's Remorse' in my life! - and get a couple of these...
... Yes; I have read Hugh's explanation of the difference between such devices and a true diffuse-field mic ... :)
[BTW... someone queried my 'newbie' status on this... most of us are newbies in some aspects of the wonderful world of sound and I'm happy to confess that I've previously not bothered over-much about near-field and diffuse-field. In other news, I'm finally starting to experiment with MIDI!]
Mike Stranks wrote: Mon Feb 28, 2022 10:02 amIn other news, I'm finally starting to experiment with MIDI!
:shocked::o:crazy:
Mike Stranks wrote: Mon Feb 28, 2022 10:02 amIn other news, I'm finally starting to experiment with MIDI!][/size]
We will make you a MIDI guru yet, Mike! :D:thumbup:
Posts: 20927 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
