Distorted Audio, Behringer XR18 to ProTools via USB, Windows Computer
Re: Distorted Audio, Behringer XR18 to ProTools via USB, Windows Computer
Michael Murray wrote: Tue Aug 09, 2022 6:12 pm James, could you provide a link to the Reaper software which you deem is reliable? I think I am a little off put (perhaps unjustifiably) by the appearance of the website I am looking at on my side of things. Maybe I have the wrong link.
You can download Reaper from
https://www.reaper.fm/download.php
Just choose the version that matches your operating system. I'm still on V6.63 but V6.64 should be reliable because it has been out for a relatively long time (for Reaper) - any bugs tend to be squashed pretty quickly by the developers.
I've not used it with an XR18 but I have used it a few times with an X32 for many hours at a stretch with no problems.
Posts: 15673 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by Michael Murray »
James Perrett wrote: Tue Aug 09, 2022 9:52 pm
I am on the verge of being done with ProTools based on the amount of problems I regularly encounter that demand troubleshooting. In my mind I conceive of audio signal capturing as an essentially straightforward process but ProTools manages to make it hard for me , but this is what I learned to work with in college audio classes. For example , some of the solutions offered above regarding "clock timing" aren't accessible as the ProTools menu has changed and the solution isn't readily available on the internet...or I'm just not phrasing it correctly. When I attempt to change the clock settings via the session tab in ProTools , it is greyed out and refers me to "See Control Panel" . What control panel ? Windows ? A search within the application itself reveals no Control Panel . I hope that I can have reaper offer me a solution or perhaps Adobe audition , though the latter seems less used in the practice of live recording. Thanks for your assistance.
Michael Murray
Posts: 12 Joined: Wed Jul 06, 2022 4:10 pm
While I would suggest that it would be better to learn the standard Reaper, you can also download Reaper Themes that make it look more like Protools with the Protools keyboard shortcuts also available. It is worth watching a few of Kenny Gioia's videos from the Reaper Video page
https://www.reaper.fm/videos.php#DIuNcKfWx1o
Post by resistorman »
Most engineers I know use Reaper for live recording, particularly on Macs. You can download/ install it and hit record in a matter of minutes, we did it the other night when a band wanted to record off the house XR18 using an old Air.
resistorman
Posts: 2869 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
resistorman wrote: Wed Aug 10, 2022 3:33 pm Most engineers I know use Reaper for live recording, particularly on Macs. You can download/ install it and hit record in a matter of minutes, we did it the other night when a band wanted to record off the house XR18 using an old Air.
Ok so now hear I am at the scene of where I intend to record , new computer and the distortion is even worse ...so it has to be the XR18 itself or a clocking issue ? Do I need any particular drivers installed for the 18 to work ? Because now I'm scrambling a bit and frustrated. I opened up Reaper and when I used the Scarlett at home...everything was fine! Now I'm at work and it is not even showing signal coming in. Again any help is greatly appreciated.
Michael Murray
I'm wondering if you have set up the routing in the XR18 so that you have a feedback loop from the computer output back to the computer input? Reaper will automatically mute if the signal level goes too high due to a feedback loop.
Michael Murray wrote: Wed Aug 10, 2022 11:52 pmDo I need any particular drivers installed for the 18 to work ?
No, if you're connecting to a Mac. Yes if its a Windows PC. The Windows USB/ASIO driver can be found in the Software section here:
https://www.behringer.com/product.html?modelCode=P0BI8
The setup is described in the manual (available in the Documentation section).
Posts: 41743 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hugh Robjohns wrote: Thu Aug 11, 2022 12:11 am
So this is precisely the link I went to and downloaded the USB driver option , not sure if it's going to work but certainly going to try... What a mess.
Michael Murray
Post by matt0314 »
I am having the same issue on XR18 recently, may I know if this issue has been solved by either increasing buffer size or change the routing? 🤓
matt0314
Posts: 1 Joined: Tue Nov 12, 2024 9:48 am
