replacement PSU for Hydrasynth ?
Re: replacement PSU for Hydrasynth ?
N i g e l wrote: ↑Mon Aug 08, 2022 10:52 pmMartin Walker wrote: I have heard that the ASM PSUs can be a bit wimpy (non-professional technical term) at times, but unless you've had the Hydrasynth a few years already I suspect ASM (or their UK
I hadnt heard that, I couldnt find any scandal on the internet, just links back here [!] and to some bloke complaining that the PSU was external and that the keyboard was too short
Just to show how impeccable my Internet searches are, here's a Gearspace post dated August 2021 you might find extremely enlightening
"My HYDRASYNTH had the start up issue as all the screens flickered and didn’t boot. I sent for a repair and the problem persisted after working all right for a few days.
I eventually returned the Hydra in spite of it being one of my favorite synths. It seems the error was caused by a cheap PSU they use."
Its part of a huge 177-page Hydrasynth thread here on Gearspace: https://gearspace.com/board/electronic- ... st15579565
Posts: 21476 Joined: Wed Jan 13, 2010 8:44 am
I called out the cheap PSU in my EM review. Strange that it's the one place they cut corners.
- resistorman
Frequent Poster - Posts: 2869 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
resistorman wrote: ↑Tue Aug 09, 2022 4:12 pm I called out the cheap PSU in my EM review. Strange that it's the one place they cut corners.
Sometimes re-badged PSUs can end up sourced from several manufacturers, or get changed during production if found to be lacking in some respect.
Given this history of previous wimpy PSUs, it may be that the power supply that ASM are now shipping has a better spec than early models (my Hydrasynth 4-octave keyboard version bought exactly a year ago in August 2021 has been fine thus far).
Because of this, I echo The Elf's suggestion that N i g e l see if he can get a free replacement from ASM , especially as the deluxe version has the same voltage but double the current capacity - that would solve the problem once and for all!
Martin Walker wrote: ↑Tue Aug 09, 2022 4:18 pm Because of this, I echo The Elf's suggestion that N i g e l see if he can get a free replacement from ASM , especially as the deluxe version has the same voltage but double the current capacity - that would solve the problem once and for all!
I have initiated contact with ASM.
My stats:
synth bought March 2020,
Home use only (but given 2020 & that the HS was new & awsome, it got a good share of play)
PSU is a small wall plug with the international pins being a circular twist & click arrangement.
unusual but nice as all other PSUs in my collection are linear slide 'n' click.
Apart from the LINE6 which is slide click fall off.
My only other ever failed PSU was on an MX200 where the internal fuse failed.
As it was a sealed unit that I had to dremel open, that knoweldge was useless.
UPDATE:
oh that was quick ! No dice from ASM, I have to contact the distributor.
I'm not sure that's entirely fair. Distributors are appointed as the regional representative for the manufacturer. So it seems entirely fair and appropriate to send a support request to the local distributor, especially since this request involves a UK specific PSU replacement.
Posts: 41727 Joined: Fri Jul 25, 2003 12:00 am
I just think it was a chance to shine. They didn't. That's an opportunity missed IMHO. The best companies understand and make the most of these opportunities, even if it means bending their protocols.
I'm just back from a Disney holiday. Now they know how to do it. If it were *my* company...
I think you're both right. It would have been a cheap and easy win for ASM (and had I been ASM I'd have just got it sorted) but ultimately from the consumer's perspective responsibility does lie with the distributor, even if the distributor gets that back-filled by the manufacturer up the line.
Edit: I do have some experience of being a vendor and there are often subtle things about the supply line that consumers will never see or understand but, however it's delivered, customer support should always be good.
One thing ASM could take away from this if they chose to is that the quality of the PSU is as important as the quality of the synth.
Neither my original Hydrasynth or the Deluxe had anything like the same issue and it does sound as if there could have been a batch of PSUs that could have been better. As to whether that's ASM's fault or the distributor I can't say but it's a shame that either way it's the end user that has the problem.
Hopefully the distributor will be able to help.
Posts: 9551 Joined: Wed Sep 01, 2004 12:00 am
Eddy Deegan wrote: ↑Tue Aug 09, 2022 10:50 pm I think you're both right. It would have been a cheap and easy win for ASM but ultimately from the consumer's perspective responsibility does lie with the distributor, even if the distributor gets that back-filled by the manufacturer up the line.
Which could all have happened 'magically' behind the scenes...
The Elf wrote: ↑Tue Aug 09, 2022 10:52 pmEddy Deegan wrote: ↑Tue Aug 09, 2022 10:50 pm I think you're both right. It would have been a cheap and easy win for ASM but ultimately from the consumer's perspective responsibility does lie with the distributor, even if the distributor gets that back-filled by the manufacturer up the line.
I agree, it could have and it's a shame it didn't. But the absence of spectacular service doesn't necessarily equate to bad service either. In this case, if the distributor sorts it out (as they should) then it's 'good' service, if not world-class.
Hugh Robjohns wrote: ↑Tue Aug 09, 2022 10:23 pm this request involves a UK specific PSU replacement.
The PSU is electrically world compatible, supplied with a variety of seamless pin adaptors eg UK, Europe.... other places.
Its late ! but I think the ultimate responsibility lies with the manufacturer.
Donahugh v Stevenson, "slug of gin-jah" precident - a slug at the bottom of the ginger beer.
The onus was on the manufacturer of the ginger beer not on the cafe owner who served it [distributor].
I will churn through the process & do battle but ultimately I think I will be reporting the product & specs of the £7 replacement from an independant vendor, possibly but not limited to CPC/Farineli.
Now that im out of warranty I also have thoughts about incorparting the psu inside the synth
Personally, I have a cubic meter of wall warts and line lumps of all types collected over the years. I would just reach into the box and grab a 12v 2A or higher supply and get on with it. I might even do so if it was still in warranty.
- resistorman
The PSU supplied with your unit in the UK may have come with a full set of adapter plates, but are you sure every territory receives the same all-encompassing set?
I wouldn't be so certain based on my experience of receiving review kit directly from overseas distributors...
Ultimately, yes, I'd agree... but I don't think it unreasonable at all to use the local distributor as the first point of customer support. It neatly avoids problems with languages, time zones, international shipping, customs and taxes, and is legitimately justifying some of the profit margin distributors take!
In the UK, the ASM distributor is Source Distribution and I've always found them to be extremely helpful and easy to deal with.
I note the psu rating for the deluxe model states it must supply more than 2A, which implies a 1A rating on the standard model might be a little tight.
Hugh Robjohns wrote: ↑Wed Aug 10, 2022 9:53 am I note the psu rating for the deluxe model states it must supply more than 2A, which implies a 1A rating on the standard model might be a little tight.
I suspect we're all agreed on that, given that at least several hydrasynth keyboard owners have experienced the same weird bootup problems
I've just unplugged my PSU (bought exactly one year ago) and it is labeled 12V 1.0A, so I suspect my Hydrasynth could be on the borderline juice-wise as well.
Well I have no way of knowing for sure but my boxes have none of the usual variant markings that would indicate a specific region and the contents were globally compatible.
Martin Walker wrote: ↑Wed Aug 10, 2022 4:45 pm
just to be clear, mine is an Ull power ICP12-120-1000D
which looks similar to this [ignore the USB stuff at the bottom, its got the barrel connector]....
...while mine, although looking very smilar, has the designation:
FJ-SW126120 1000DN and simply says 'MADE IN CHINA'.
Interestingly, the PSU for my Explorer has a slide-on plug adapter instead of a twist-on with a tab to push in to release, and is also rated for 2A.
Considering it has (as far as I know) the same board that the regular Hydrasynth and the Desktop version have, it would appear they're aware of it. Curious that the Deluxe (which I assume just has 2 boards in it) also has a 2A supply. Glad they're generously provisioning the new ones though.
