Home Studio - Do I go audio interface or mixing console
Re: Home Studio - Do I go audio interface or mixing console
Hmmm. I wrote a reply earlier but it doesn't seem to have posted. I blame my fat fingers.
It was along these lines...
Unless I was looking for something that was going to double up for live use, then I'd be looking at an interface. If I still wanted to get hands on with faders (and I do) then add on something like a Behringer X-Touch of some kind.
Probably the cheapest way to get 16 channels in is via a Tascam US16x08 but it doesn't give you any expandability. So I'd probably look at something like an Audient EVO16 and then expand via their EVO SP8 (or similar) which I think will allow you to go up to 24 channels (at base frequency rates).
Going up a notch price wise opens the door to RME and their total mix software as well as their ongoing product support.
But if you really do want to mix on the way in it might be worth looking at the Tascam Model 24?
Posts: 27699 Joined: Sun Jul 05, 2015 12:00 am
Like some others here, totally agree in that it depends how you work. I have a lot of keyboards, synths and modules, so 30 + stereo inputs to connect in if they were all connected at once, which is never the case. I’m a keyboard player who occasionally mixes in guitar and drums with mates. Tracking is important to me because I play by ear, and I love a great sound. I’ve mentioned two systems below that I have paid for and use, for my own playing, recording rehearsals to improve a band or group, and critical listening to music to learn it.
I have used RME interfaces as the backbone for recording for two decades now, used to be three firefaces. Four years ago I started using the Apollo X16, having already invested in a fair bit of UAD plugins to get the Neve colour I craved. As others have indicated RME have been super reliable with ensuring their gear remains useable with each Mac or Windows OS. Their sound quality is excellent, and the only maintenance costs have been recapping the power supplies. The only problem in NZ has been getting RME gear, that’s changed now. RME reliability with their drivers, and clever engineering means I can plug unbalanced or balanced leads into the firefaces and route whereverI choose. RME remains my reliable transparent recording solution. Each RME firefaces 800 unit cost NZ 4.5k in 2007 and 3 of them and getting here cost around 14k in total. Other RME gear added in the last 2 decades are a Babyface pro and AIO card in a second studio mac. Original RME system was 48io at 96kHz, which was and is brilliant value for money when you consider how long it’s lasted, how flexible, and reliable it is.
Recently I purchased two of the Korg MW2408 mixers and put each of their 8 buses into the Apollo x16, and connected the 16 outs into each of the Korgs 8 mono inputs, it’s early days but I’m loving the simplicity and the tracking through Neve perception. The Korgs were very cheap here, NZ1200 each , and with each of them having 8 stereo inputs, they make a very good analogue front end to a UAD setup for keyboard hoarders like me. Unlike RME - the UADs don’t have a total mix equivalent so having a real mixer with a small footprint that has useful number of bus outs and the ability to custom mix some headphone outputs is great for band practice and recording a rough mix. About to add in 2 x ssl patch bay NZ so I can choose to switch which synths are connected to the korg mixers and the RME matrix at any given time. This analog system cost NZ8k for the Apollo in 2019, 2.4k for the korg mixers, 2k for the SSL x patch units, and is effectively a 48in 16 out system at up to 192kHz with the ability to patch in outboard or plugins without sacrificing inputs. So NZ12.4 k for a more complex but colourful option, and I’ve yet to determine it’s reliability. I expect it won’t be as good over the long term as the rme system has been given UADs support for constantly changing evolving computer systems. That said so far I am loving the sound and simplicity of the analog mixer with UAD and the option of some colour if I want it.
I’ve not factored in the various costs of leads to connect it all, and I can’t readily factor in all the pros & cons of other gear that’s come and gone in the last two decades, but suffice to say sometimes you go down a path trying to get “that sound” and you realise it’s an unreliable and expensive waste of time. I poured a lot of time and money into an Allen and Heath GSR 24M mixer because I loved the sound of synths and plugins through it, but my space is too dusty and that mixer comes with a maintenance cost, and repairers are not easy to find here.
Just as a slight aside - I tried the Tascam Model 24, and I was quite impressed, it did what I wanted. I am sure I read somewhere that if you had it in interface mode, you couldn't record a track back from a DAW to the SD card, seemed a bit counter intuitive, I thought that was the point of the thing. Anyway, I found that I could record to and from the DAW.
After a little while, the output started breaking up on one channel of the headphones output. It was one of those really irritating faults, I would jiggle the connector, it would spring back to life, then I'd settle down to do some tracking and it started playing up again.
What put me off though was that before I sent it back, I thought I would imagine the circumstances where at some point in the future I would need it repairing, and I looked about for companies that offered repairs on Model 24s and I could hardly find any. I returned it although was sad to see it go.
For not recording purposes, I dont see the point in having a digital mixer unless the integration as daw controller is excellent, which does not happen with any of the models mentioned above
I’d much rather go with a GOOD daw controller and a GOOD interface.
For recording, or if you are going to actually mix on the console, I’d have an analog with all inputs routed to the interface.
In the studio, where I record I have a Presonus Quantum 4848 hooked to an old Soundcraft 6000 and some other preamps.
At home, where I do everything else, I use an Apogee element with an Avid dock and pair of S1’s, and it’s been great so far.
- ore_terra
Posts: 1073 Joined: Fri Dec 02, 2016 12:56 pm
casmoestudio.com
From years of reading SoS and this and other forums I would say "RME and some ADAT units (and possibly pre amps IF you feel they will make a difference/impress the punters")
I can see the attraction of sitting behind a large desk decked out like the flight deck of Enterprise but in truth how many of its facilities will be used for basic tracking?
But 6mx 6m (height?) is biggish space to monitor in and the bands will surely want to hear 'rushes' at near real volume? This means some serious monitor speakers and, along with room treatment, is where a very decent chunk of the money will need to be spent. There have been a few monitors reviewed in SoS that can meet the SPL needs of midfield monitoring but around £8k seems the price point.
The Fireface UFX ll would be a good starting point at around £2k then expand to taste with ADAT units. A small rack would make for a very compact and tasty setup!
richermusic wrote: ↑Sat Jan 28, 2023 12:52 pm All of this sounds quite useful.
Another thing I am not sure about is the sound quality. If I was to get something like the presonus or behringer then Am I going to hear much difference between them and something like the Apollo X16.
I know that with some of this, it’s how long is a piece of string but if it was all through the same mic etc then when doing a direct comparison, are you going to notice.
All interfaces have a sound, that’s a fact.
Price doesn’t determine "the sound"
The final decision is based on what you like, not what others tell you you should like, sometimes these decisions go against what the general consensus is, but that’s the same with everything, and buying something that you haven’t heard in your context, is like buying a car without driving it.
Bottom line is it’s up to you, I could recommend various things, but these are my preferences, not anyone else’s.
I’ll be honest, my budget is virtually unlimited, I use two Behringer interfaces, and a Motu.
Arpangel wrote: ↑Sun Jan 29, 2023 8:21 am
... and on those criteria, the same is equally true of all mixers...
- Mike Stranks
Jedi Poster - Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Eh?
In a double-blind assessment - which I think is what Dave is suggesting - then no-one involved has any way of knowing what they were listening to until after they've made their preferences clear.
- Mike Stranks
Mike Stranks wrote: ↑Sun Jan 29, 2023 8:43 am
Eh?
Indeed Mike but at the time the SoS instigators were at great pains to point out that the pre amp tests were not true, 'scientific double blind tests'.
For those that don't know...A 'robot' piano played the same piece of music and several different pre's of varying price were recorded. The readers were then invited to list their preferences/guesses. IRRC the results were no better than chance?
ef37a wrote: ↑Sun Jan 29, 2023 8:55 amMike Stranks wrote: ↑Sun Jan 29, 2023 8:43 am
Eh?
Ahem... Some of us got pretty close...
The Elf wrote: ↑Sun Jan 29, 2023 8:57 amef37a wrote: ↑Sun Jan 29, 2023 8:55 amMike Stranks wrote: ↑Sun Jan 29, 2023 8:43 am
Eh?
Maybe but it was still a guess!
If any "quality" tests are so close, that a guess is required, then AFAIC I’d probably be happy with any of them, it seems a lot off folks these days are getting a bit too obsessed with things on a microscopic level, that don’t really matter in the real world.
In which instance, just in case you haven't considered this already, haven't done this already :
purchasing music gear for deprived Schools in London.
There are so many deprived Schools in London they would be over the moon to receive just a few bits of music gear.
Also for deprived community centers in London.
In the approx 200 towns in London pretty much most of them have a community center with plenty of them deprived.
- tea for two
Frequent Poster - Posts: 4015 Joined: Sun Mar 24, 2002 12:00 am
Just about every audio interface can give you acceptable sound quality these days. The differences are down to:
1. Whether it can handle the inputs and outputs that you want to use. Some people need full professional level capability to connect to older gear but not many audio interfaces can output +24 or +28dBu. Another issue seems to be a lack of headroom in mic preamps with certain interfaces.
2. Whether the drivers are reliable and capable of low latency. Check things like is it easy to change sample rate or change clock source?
3. Is the manufacturer well established and are they quick at supporting new operating systems for their old interfaces? Many manufacturers rely on third parties to write the core of their drivers so don't have the expertise to support their products if that third party no longer wants to support them.
Posts: 15670 Joined: Mon Sep 10, 2001 12:00 am
" Another issue seems to be a lack of headroom in mic preamps with certain interfaces."
I agree James and this is always going to be a bit of a problem with 'simple' AIs with a single mic gain control. The designer then has to strike a balance between enough clean gain for a dynamic mic or decent headroom.
Most seem to plump for higher gain on the basis I guess that many home bods will, initially at least, go for a dynamic mic. Should they aspire to a hot capacitor they can buy XLR pads.
FYI I checked my M4 and it has a max (min gain) input level of +10dBu or 2.5V rms for jazz. Pretty good methinks and it certainly has the low noise and gain for a '58.
James Perrett wrote: ↑Sun Jan 29, 2023 11:47 am Just about every audio interface can give you acceptable sound quality these days. The differences are down to:
I can put up with poor support, "if I have to" if sound quality is good.
What some people are "suggesting" is that that’s up for compromise, if driver stability and customer support are priorities.
In the heady world of pro recording, these issues occur all the time, how many times have we been told quality is unquestionable, it’s an "industry standard" bit of kit, industry standard? It’s rare you get something that ticks all the boxes, including the one that seems to be way down the priority list for some users, and that’s sound quality.
I’ve paid a lot for interfaces that have great driver support, great build quality, great compatibility etc etc, but they sound awful, I can’t sit there and listen to them for more than a couple minutes before I want to throw them through the window.
Of course, it is possible to have it all, and most of the interfaces that I like are plug and play, no drivers required, and they never break down, so a lot of these issues just don’t apply.
tea for two wrote: ↑Sun Jan 29, 2023 10:46 am
I’ve given away more gear than I can remember, and if you can show me an individual, that has talent coming out of every orifice, and the only thing holding them back is money, I’ll be there.
But just like foreign aid, you can never be sure it gets to where it’s intended.
Tony - I think what you are trying to say is that you disagree with everyone else here when it comes to RME.
What you seem to ignore is that RME interfaces have plenty of digital connections so no-one is forcing you to use their convertors although most people's reaction to their convertors is very different to yours. The only rational explanation that I can think of is that you heard the analogue output from one of the original Hammerfall cards which was intended to be used for convenience rather than quality.
As I recall a few people did identify most preamps correctly, but it was only a few, and no one got them all right.
The results of the 'preferences' survey are here:
https://www.soundonsound.com/reviews/preamp-post-mortem
The really striking thing was just how widely spread and inconsistent the reported views actually were.
Posts: 41729 Joined: Fri Jul 25, 2003 12:00 am
My main take from that article was that there were a host of other things I needed to get on top of before I started worrying about the pre-amps in my interface.
... is the correct answer!
