Recommend secondary studio monitors, but not for mixing
Re: Recommend secondary studio monitors, but not for mixing
Ben Asaro wrote: Wed Mar 22, 2023 12:33 pm I have a pair of small Eris monitors for as well, also used for non-critical synth monitoring. They work fine!
I bought a pair of Eris 3’s, because they were cheap, had the inputs I needed, and were light and small, for taking out and about, the only issue I have is that they sound like two cardboard boxes.
Posts: 19419 Joined: Sat Jul 12, 2003 12:00 am
Post by Mike Stranks »
From left-field...
I have a couple of these:
https://www.thomann.de/gb/the_box_pro_achat_104_a.htm
Which I use for utility duties (and small voice-only PA).
I guess you could augment them with one of these:
https://www.thomann.de/gb/the_box_pro_a ... 8_suba.htm
Jus' a fawt... :)
Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Mike Stranks wrote: Fri Mar 24, 2023 10:08 am From left-field...
Jus' a fawt... :)
I bet these aren’t half bad either, their own brand is normally very good.
