More suggestion to diagnosing/fixing earth hum
Re: More suggestion to diagnosing/fixing earth hum
Dave71 wrote: Fri Mar 24, 2023 12:03 pm I’m away from home now but just removed a couple of socket screws from my partners surface mount utility room sockets. They’re both Mk and have a small brass insert in the screw holes linked to the earth - I thought that was a standard?
The only ones I have which don't have the screws earthed are similar to these https://www.screwfix.com/p/british-gene ... pack/455xf
Posts: 21523 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
I have come across installations with metal back boxes where the earth wires from the cable aren't linked to the box at all, just the front sockets. In most cases the retaining front plate screws still pick up the earth as they pass through the holes, but not always.
Posts: 41714 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Actually, now I think about it, all the sockets have earthed eyelets in the screw holes anyway :oops:
I must have fitted dozens over the years and when I saw that those plastic back boxes didn't have any earth connections I never made the connection (pun intended) between the two and assumed the screws would be unconnected too...
Post by Dave71 »
Update. Swapped the socket out for a new one with the earthed screw holes and tried Hugh’s original suggestion of providing an earth to my signal chain - no joy. Ran an extension upstairs from a socket closest to my consumer unit to rule out a weak earth link in the ring main.
Still requires me to touch something to stop the buzz.
Borrowed another guitar (usa strat) expecting the single coils to be just as bad but found this to be significantly better.
Going to see which appears to be the worst guitar and experiment with cavity shielding.
Dave71
Posts: 415 Joined: Thu Apr 21, 2005 12:00 am Location: Probably sat down
Hurrah! :D
