Acoustic guitar sustain increase device?
Re: Acoustic guitar sustain increase device?
Agreed, and a Gypsy Jazz guitar is probably a good way to compare as they are otherwise similar. However, a knowledgable Gypsy Jazz player/mate has said that the bracing is different on the f hole models. Not sure how different but the luthiers will be along soon to explain no doubt. If you do fb it's here but it's a closed groups you may not be able to read the posts :- https://www.facebook.com/groups/363471863725904/
Forum Aficionado - Posts: 22907 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
blinddrew wrote:I'm with Dave! Grab a clamp from the garage and a couple of bits of cardboard and see if it makes a difference!
I clamped a small metal vice grip, or 'locking plier' (about 6 oz) to the head with some cotton cloth in between the clamp and guitar.
I recorded the song both ways, with and without the vice-grip.
With the vice-grip on, the guitar is quieter and the bass is lacking. The instrument is not as expressive sounding and sounds, well, clamped a bit - especially the bass. The bass is open normally but not boomy and certainly not clamped. One reason I like the F-hole is the guitar does not have that 'hole' sound that you get when recording a normal acoustic. The lack of a hole means I can mic it where it sounds beautiful but I don't get that hole boominess sound. You get the deep bass, but without the boomy hole-sound. But with the clamp, the nice bass has been reduced. It sounds like the guitar is not resonating, especially the bass tones.
There is no noticeable increase in sustain. Even if there was, the change in depth of the sound would not be worth it.
I moved the vice-grip around a bit on the head, but I can't discern any real difference in where I place it. It seems to reduce the volume and bass no matter where it is and doesn't do anything for sustain.
- DC-Choppah
Posts: 2054 Joined: Fri Jul 20, 2012 12:00 am
Wonks wrote: Some can have amazing sustain, but it's not down to a lump of metal on the headstock.
That certainly jibes with what I am hearing when I tried adding mass to the head.
How about a heavier E string?
It is really the top string that needs more sustain. I am feeling that the notes on the high string decay too fast, while the notes on the lower string are actually good. Sort of out-of-balance.
I am using these: http://www.savarez.com/argentine-boucle-1510mf
I wonder how much higher in thickness I can go than .011" on the top E string and if that will give me more sustain?
I would switch back to the normal set after this recording. I am just trying to do something for this particular song.
- DC-Choppah
Sam Spoons wrote:The Maccaferri design came from his desire to build a louder classical guitar so I suspect compromising sustain was not on the agenda.
Yes, that is it exactly. That is how I think of this guitar - a louder, classical guitar for playing jazz. I love the beautiful tone.
I play contemporary jazz with it, and also swing in a big band with pickups, and also Gypsy jazz. I really just use it as an acoustic jazz guitar, not just a Gypsy jazz guitar.
It does feel and play like a classical guitar but without nylon strings. The strings are silver coated classical guitar strings.
- DC-Choppah
DC-Choppah wrote:The strings are silver coated classical guitar strings.
Well, not exactly, the construction and tension is completely different. The Argentines (which I use on my Aylward BTW) are steel cored, like normal electric and acoustic strings but the windings differ, 'normal' strings are Nickel, Steel wrapped (electric) or Brass or Bronze wrapped for acoustic strings. The key difference is that Argentines are copper wound with a silver coating. Classical strings use a number of different windings (including silver plated copper). Modern ones usually have a nylon or composite core. Macaferri's original guitars used the standard classical strings of the day with solid gut trebles and copper wound on a silk core basses.
Changing just the top E will not do any harm to the guitar and the slight increase in tension will most likely increase sustain (in fact I use 10s on the Aylward but am considering trying an 11 top E as it sounds a little weak. It is due for a restring though so I will do that first in case it's just the old strings causing the issue).
Thanks for that. I am going to try a .012" and .013" on the top.
You showed me how the guitar can actually accept ball end OR loop end strings in another thread. Cool! I hope it does not sound out-of-balance with a unique top E string in there.
Here is some beautiful music that has this wonderful guitar sound I am hearing. Bireli Lagrene - Storyteller. https://www.amazon.com/Storyteller-feat ... B07HZ6CNBH
His acoustic guitar has that wonderful tone of the Gypsy style, but with long sustained notes. Listen especially to the contemporary jazz version of Stella by Starlight. That is the sound! Wonderful record.
- DC-Choppah
Replaced the top two strings with .013" and .017". Getting good sounds with the right kind of sustain. It did not sound right with just the E string replaced - the B string sounded whimpy.
Here is me doing a little Larry Carlton melody that this sound reminds me of.
https://drive.google.com/open?id=1WLNhA ... LXNxzke39j
- DC-Choppah
Bireli usea several different guitars, the one on that Stella recording does sound like a Selmer/Macaferri type but on this youtube he is playing an electric arch top. It doesn't't sound like the CD version though...
https://www.youtube.com/watch?v=_gjUANhT6l4
Sam Spoons wrote:Bireli usea several different guitars, the one on that Stella recording does sound like a Selmer/Macaferri type but on this youtube he is playing an electric arch top. It doesn't't sound like the CD version though...
Cool. That version of Stella was about 20 years ago. The Storyteller record was just released. He's probably played Stella like a million times between.
The reverb sounds on the Storyteller record are so lush. Man, what is that all about!
- DC-Choppah
