ef37a wrote: ↑Mon Jun 05, 2023 2:11 pm
Evidence James?
Mainly from the number of faulty interface posts we get on here.
Taking into account the much greater number of people (often with little understanding) that buy audio vs. MIDI interfaces? I can see how the former might be more susceptible to obsolescence though.
Evidence James?
As a long time lurker on the forum I would say the incidence of AI failures reported was incredibly low? Especially since almost everyone here uses at least one! Even then, some of the "faults" turn out to be 'finger trouble' and kind suggestion to "RTFM" often sorts the poster out!
It also seems to me that James was really referring to AIs that were 'orphaned' by OS changes? That is more a question of 'politics' than of reliability.
I don't know but I suspect MIDI only interfaces use a 'generic USB MIDI' driver and that does not change with OS upgrades?
But my main beef with AI manufacturers of some quite costly interfaces is the 'bean counter' attitude plus the fact that MIDI capability has been a feature of AIs right back to Sound Blaster days.
Just discovered a fault in the PSU of my 1820, where the lead goes into the in -line "lump" it’s shorted out, the wires are stripped at that point, I tried another PSU, correct voltage but not the right amperage, and the 1820 works, this is really bad, it must have been like this since new, as it’s just been sitting I my rack, that would explain the burning smell.
Trouble is, I can’t seem to find the correct replacement PSU, it needs to be 12v 2000ma centre negative, I’ve found a My Volts PSU it’s described as being for an 1820, but it’s centre positive, is this important? and can I use a generic PSU?
You definitely need a centre negative PSU. Centre positive won’t work and could damage components if they haven’t fitted reverse polarity protection.
The spec sheet says 20W max. power consumption, so at 12v that’s 1.66A/1666mA. So you’ll need a PSU that can supply at least 1700mA, but it can have a bigger capacity. Yes, it can be generic.
Wonks wrote: ↑Tue Jun 06, 2023 8:33 am
Thanks Wonks, I’m going to Cricklewood electronics later, hopefully they’ll have one.
Tony, are you ABSOLUTELY sure that B'ringer is centre negative?
That odd polarity is almost exclusive to guitar pedal supplies for variously contested reasons. Bloody silly of Behringers to do that if so.
As Wonks says, provided the supply can deliver around 2 amps at 12V most will be fine but I would suggest buying from a reputable source such as RS Comps or CPC/Farnell and not some 'no name' tat online.
I am sure CPC will do a properly rated supply and one with a 'universal' set of connectors so you can get the (VITAL!) polarity right. PLEASE tell me you own a digital test meter?
Wonks wrote: ↑Tue Jun 06, 2023 9:04 am
It is centre negative, or at least the graphic by the power connector on the interface says it is.
Yes indeed. I have managed to find a rear view with just good enough resolution to confirm.
THAT is bloody daft and an accident waiting to happen. I have and have had dozens of rat powered bits of kit and none have been centre negative except guitar electronics.
ef37a wrote: ↑Tue Jun 06, 2023 8:59 am
Yes! I do! as for knowing how to use it, that’s a different kettle of doo-daa!
I got a huge belt off that PSU, thought I was going to die! I couldn’t let go of it, I think I touched a charged capacitor, that’s the biggest electrical shock I’ve ever had, and they were tiny capacitors.
WARNING!
WARNING!
FORK!! TONY!! You easily COULD have died! That cap in a SMPSU rat is charged to peak mains voltage, about 330 volts and there is over a hundred times enough current available to stop the old ticker. Wired the right way it could probably kill a horse! (disconnected from mains there will be a residual charge that might be lethal to us wrinklies but would just be a painful surprise to a healthy person)
Wee power supplies like this are really so cheap that it is never worth taking the risk of opening one up. Heed the warning! "NO user serviceable parts inside"
ef37a wrote: ↑Tue Jun 06, 2023 9:10 am
I guess you've never owned any Philips kit then Dave. The PSU for my Philips cassette recorder (which also powered their their transistor radios and their portable record players) was centre negative. It also worked fine with guitar pedals.
Ha! I used to service Philips kit for a living James along with many other brands. Philips ALWAYS did things differently from other manufacturers! They managed to build a radio without tagboards or printed circuits. They never used standard cartridges or styli for their pickups and their tuning dial mechanisms were a baffling array of mini "Bowden cables" instead of the dial chord everyone else found perfectly satisfactory. They even had to have their own, bespoke mains connectors way before IEC plugs were developed! And do NOT get me started on their microphones!
So, not at all surprised Philips did different. IIRC most of the early 'piano key' mono cassette machines used a mono 1/8th jack for DC power? Not of course the best solution.
Arpangel wrote: ↑Tue Jun 06, 2023 8:24 amJust discovered a fault in the PSU of my 1820, where the lead goes into the in -line "lump" it’s shorted out, the wires are stripped at that point... it must have been like this since new, as it’s just been sitting I my rack, that would explain the burning smell.
It probably does explain the burning smell, but I can guarantee it wasn't like that from new. The lead has been tugged or stretched during or after one of your racking or re-racking efforts.
Re: Interface failed, need a new one, any recommendations?
And some older Roberts radios
Weirdos. Roberts did make nice radios mind. Never came across one with a power socket. Maybe 'after my time'?
I'm sort of glad I read this post, and about the 'fix' I was seriously considering buying a Berry UMC1820, as a spare interface, they seem such good value. But then read about it conking out after just as few years and though "uhoh, that's the Berry Curse again, abandon all hope ye who enter"
But now it seems maybe I was erring too much on the cautious side and the UMC1820 is good value after all. Hmmm, sat here in the studio, should I grace my place with that interface?"
I doubt anyone could argue One that the 1820 is not great value?
As for the other Behringer "problems"? Well, I have had several of their products and yes, not what you would call "rugged" but in a gentle 'domestic' setup, perfectly fine.
I was quite impressed with my UMC204HD, especially the mic pres. Decent amount of gain and low noise. My only real criticism would be the low output level. Max out is IIRC only +4dBu. That may not matter in your situation and in any case the 1820 might be a bit hotter?
ef37a wrote: ↑Tue Jun 06, 2023 3:10 pm
Yes you have a point there Dave. I was however considering the Berry as a backup t6o have just in case my current interface (RME) goes pop. Hope I am not tempting providence by writing this!
Casio, Korg and Roland use(d?) centre negative supplies as well as do Brother label printers. Thinking of the last one I'm nearly 100% sure that the PSU that came with my PT-600DB is 12V 2A and it's definitely centre negative. Though at the moment I'm using a spare 4A psu from a TV that I've swapped the polarity on.
Edit: Brother AD-E001UK would probably be ok 12V 2A centre negative.
Could be that time I ripped it out of the rack, and threw it across the room, when I lost patience with it.
I must stop doing that.
Dave, we just bought a Roberts Revival Stream 3, it’s excellent, it’s got that lovely bassy warm sound, and the build quality is up to the usual Roberts standard.
Their after sales is amazing, a friend had a 70’s Roberts, they repaired it for him and rang him when it was ready to be posted!
