@ Elf
Just use your ears. Are all notes sharp, or do they go out further and further the higher/lower note you play? If the former it's just the tuning trimmer that's needed; if the latter you need to adjust the octave span.
The simplest way is just to play your 106 (create a 'vanilla' tuning patch - I have one at the highest patch memory on all my programmable synths) alongside the 101 (played via MIDI, obviously) and compare the tuning. I would start by using the tuning trimmer to get a perfect low C and then see if the span goes out as you play up the keyboard, changing the span if necessary. Keep going back and tuning that bottom C as your starting reference.
Im not sure my hearing could detect whether its the span or the notes.
I'm very familar with this process - I have to do it with my MiniMoog practically every time I use it!
Ever thought of ditching the Moog and getting a Studio Electronics SE-1?
SOS review 1994
Been thinking I could record a note direct from the 10 unplugged from the CV converter and record it to my pc. Then I could hook it all up again and play the same not and record that. Then play the recordings one after the other and if they sound different I will know if its the converter or the 101 that's out.
@ VCO - thanks for the info mate, appreciated
@ Vinyl Junkie - Yeah those prices are great but I can find superb prices even now. Theres a word for those though. Bargains. They dont really reflect the going rate. Mind I am not sue if the prices of Analogues through out dipped when virtual instruments became both capable and popular so that could explain 2003.
I knew a ton of people and still have a ton of 80's mags where 303's traded for 30 - 50 quid regular and 808 and 909's around 75 quid a piece.
But this is what I was saying about how the Junos price had stayed around the same by comparison when you originally said they were too expensive now.
Even if Junos have gone from 300 to 400 pounds thats a 25% increase in 25 years. A 303 sells now for around 1000 pounds and so has increased by at least 2000% which sort of pails the hundred quid fluctuation of the price of a Juno.
Nice looking studio mate, you won the lottery or something?
