adambier wrote:
The only other thing the folks from Sennheiser mentioned was potential mains power issues--I'm not totally clear one what exactly those would be, but I don't really want to buy a bulky online UPS just to ensure perfect sine waves and exactly 120V as an experiment.
I invested hours of testing after setting standby time to 1 minute:
At first, I measured my balanced outputs to the KH 80 for signal spikes (by using an audio interface connected to my high quality USB audio interface outs) but I was not able to measure them (looking at peak SNR) therefore I would rather rule this out as a cause.
1) KH 80 not connected to any signal source (leaving the XLR cables unconnected).
Ethernet cables are connected.
-> no sporadic wakeups (tested for 30 minutes)
2) KH 80 connected to an USB-powered Audio interface (without any signal, setting output level knob set to zero) with ground lift enabled on the interface.
a) Ethernet cables are connected.
-> sporadic wakeups on rather both KH 80 (after ~2 minutes), but they do not go into sleep reliably
b) Ethernet cables are disconnected
-> significant humming audible
3) KH 80 connected to an USB-powered Audio interface (without any signal, setting output level knob set to zero) with ground lift disabled on the interface
-> sporadic, more random wakeups (first wakeup after ~5 minutes),
happens much more likely on one of the two KH 80 (even if I switch the audio channels), but usually sleeps again after 1 minute.
b) Ethernet cables are disconnected.
-> sporadic, less likely (compared to 2a) random wakeups (first wakeup after ~20 minutes),
4) KH 80 connected to via an active, battery-powered DI box (ground-lift disabled). The Di box is connected to an USB-powered Audio interface (without any signal, output level knob set to zero)
-> sporadic wakeups on rather both KH 80 (after ~3 minutes)
This also happens if I set a 20db or 40db attenuation at the DI box.
This is another hint that the problem has nothing to do with the signal lines (e.g. spikes, SNR etc.)
5) KH 80 connected to via an active, battery-powered DI box (ground-lift enabled). The Di box is connected to an USB-powered Audio interface (without any signal, output level knob set to zero)
-> extremely loud ground-loop-like-humming-noise (not present when ethernet cable IS connected). Hopefully the oberload protection at KH 80 worked. I'm sure my neighbors just woke up
Not sure if this originates from my rather cheap DI box or from an issue within the KH 80.
Taking the results of above tests and obvervations into account, especially the influence of a connected ethernet cable (connecting an ethernet cable will also likely cause the KH 80 to wake up!) I suspect grounding (earthing) issues with the KH 80's wakeup/standby functionality as the most likely cause (eventually because they only have a 2-pins main connection, so the grounding reference is missing).
This would also explain the randomness as well as the strong dependency on the actual setup/electrical environment.
To everyone affected: Remove your ethernet cables (if present) and see if this reduces unwanted wakeup/standup probabillity.
adambier wrote:
Definitely not a software engineer here, but, dunno, multicast issues?
Multicast is only used for device discovery (via mDNS). Actual communication to the KH 80 happens via regular (unicast) TCP connections.
