ef37a wrote: ↑Wed Dec 08, 2021 8:48 pmHugh Robjohns wrote:Not quite. The guitar amp is supposed to provide the appropriate high impedance for the guitar. The 1M Ohm 'standard' of active DI boxes came about as a way of not loading the guitar-amp connection, and thus not affecting the tone.
Not quite sure what you are saying there Hugh?
As you know, the amplifier input impedance forms a resonant circuit with the guitar pickups, controls and the cable which strongly affects the overall tone.
The idea of a 'stage' DI box is to take a 'sniff' of the signal passing between guitar and amp -- hence the input and Link sockets being wired in parallel. In days of old, with passive DI boxes, the relatively low impedance of the transformer significantly lowered the load impedance seen by the guitar and thus changed the tone slightly, often to the grievance of the guitarist.
The benefit of the active DI box was that it could be engineered with an extraordinarily high input impedance -- borrowing a concept from audio measurement equipment -- so that its presence across the signal connection has no material effect on the overall load impedance seen by the guitar at all. 1 MegOhm was a good achievable value, and it has since become almost a ubiquitous standard.
However, in situations where an amp is not connected to the Link socket -- such as is often the case in the studio (or in DI boxes where a link socket is not even present), a 1M Ohm input impedance is considered, by some at least, to be too high. The claimed reason is that it does not load the guitar in the same way as a typical guitar amp which often has an input impedance closer to 250k Ohms... Hence the lower impedance offering of the J48.
I have read of people thinking that the guitar amplifier 'tone' is in some way affected by the source impedance feeding it. I have crossed qwertys with folk who think an amp MUST be fed from a 1meg source!
That would be daft... but the impedance of the guitar pickups, tone/vol/switching circuitry, cable and amp input all work together to construct a resonant circuit which certainly does affect (to some degree) the overall tone. Change any one element and the sound changes with it, slightly of radically depending on the change...
The input impedance of a DI box or indeed an amplifier is not as critical as many people think. 220k, 500k or 2-3 meg will probably make less audible difference than changing the cable from 3 to 5 mtrs or a different brand.
Quite possibly!
