Organ Grinder wrote: ↑Tue Oct 04, 2022 7:13 pm
Well now I'm confused! I though you had live and earth (or ground)
Ha! Ha! viz...https://uk.rs-online.com/web/p/coaxial- ... rs/5464875
Organ Grinder wrote: ↑Tue Oct 04, 2022 7:13 pm Well now I'm confused! I though you had live and earth (or ground)
Hugh Robjohns wrote: ↑Tue Oct 04, 2022 9:44 pm However, video (and digital audio and RF) are all high frequency signals that require the cable to have specific characteristics if the signal is to get to the other end intact.
Organ Grinder wrote: ↑Tue Oct 04, 2022 5:09 pm
I used an old phono cable and a coax cable soldered together
James Perrett wrote: ↑Tue Oct 04, 2022 10:49 pm As Hugh says, just any old phono cable won't work. It needs to have low loss at high frequencies and a characteristic impedance of 75 ohms. That's why the CPC cables I linked to use RG59 cable which is likely to be similar to the cable used by the BNC cables.
Oh - and just to confuse things further - BNC connectors and cables are available in both 50 ohm and 75 ohm versions. You need to make sure that you have the 75 ohm version for video and digital audio.
Organ Grinder wrote: ↑Wed Oct 05, 2022 12:01 am But they are OK for sound, but will there be any different for video?
Organ Grinder wrote: ↑Wed Oct 05, 2022 2:55 am So I need to get a 75 Ohm one. Dam! I wish I ordered it at the same time when I ordered my plug as part of the fiver handling charge
Mike Stranks wrote: ↑Wed Oct 05, 2022 9:45 am BTW; for the longer runs to and from the control room, we always used 'proper' 75-ohm coax into a Distribution Amp at the 'downstream' end.
Organ Grinder wrote: ↑Wed Oct 05, 2022 2:52 pmMike Stranks wrote: ↑Wed Oct 05, 2022 9:45 am BTW; for the longer runs to and from the control room, we always used 'proper' 75-ohm coax into a Distribution Amp at the 'downstream' end.
So the longer the cable the longer the signal and the more resistance therefore the better quality cable needed, fortunately for me this is just to test my cameras so a short distance of say a meter cable from the camera to the TV should be enough
Organ Grinder wrote: ↑Wed Oct 05, 2022 3:12 pm We are up to 10 pages now and I have not even got my first camera to work yet. BTW I have about 20 of them different makes and models, this could be a very long thread
Mike Stranks wrote: ↑Wed Oct 05, 2022 4:15 pm This: https://cpc.farnell.com/pro-signal/psg0 ... no%20leads
