Aria Sinsonido preamp repair
Re: Aria Sinsonido preamp repair
Post by Dr R »
Photograph of "Test rig" to confirm stereo wiring from pickups to output:
Maintaining a steady two-finger plucking technique while shorting one pickup with the needle-nosed pliers was hard ;)
The pickups in the Aria are, I think, in the tube that forms the bridge.
As you can see, it's a lot lighter than a typical bass.
Dr R
Posts: 280 Joined: Mon Jun 21, 2010 12:00 am Location: Solihull, West Midlands, UK
My ambition: To one day have enough experience to answer technical questions on the SOS forums, as well as asking them
ef37a wrote:Ah! "Headphones" that makes sense of the use of the LM386s.
And stereo, could be some weird phase anomaly going on?
Ding!
Posts: 20453 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Post by Dr R »
Thanks Folderol - I take it that's a lightbulb moment?
I'm don't understand how a phase anomaly would prevent the tone control from affecting the sound, though I can see how it might remove some of the bass frequency, which is also part of the problem.
More confused than ever :?
Rich
Dr R
Dr R wrote:Thanks Folderol - I take it that's a lightbulb moment?
Rich
It is often the case Rich that even quite simple electronic systems display faults that seem to make no sense and a purely logical examination of the circuit (which we have not got!) throws very little light.
Once the fault has been found however it becomes blindingly obvious that "THAT" was why it went T's U! (I call it the "Rumsfeld effect")
Posts: 18677 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by Dr R »
Thanks Dave,
Most software faults follow the same arc. The difference is I sort of know what I am doing there ;)
So what should I look for next?
Dr R
Rich
It completely explains the (otherwise incomprehensible) chip choice, and I'd be very interested to know what exactly they are doing to get a supposed 'stereo' effect. Oh, and poor LF response could be simply down to caps drying out.
I'm a bit suspicious of the tone control doing nothing at all. A simple fault would suggest only one side being affected. Also, no stereo effect at all sounds a bit strange. I wouldn't be surprised if it turned out to be something daft like a hairline fracture in a ground track.
Dr R wrote:Thanks Dave,
Folderol's postal address and bubble wrap?
ef37a wrote:
Dr R wrote:So what should I look for next?
:clap::bouncy:
Posts: 22232 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by Dr R »
:clap::bouncy:
Well that's no pressure on the good gentleman then!
Dr R
:clap::bouncy:
It's OK, these are my friends... I think :lol:
If you really are stuck, send me a priv message - I'm a sucker for an unusual challenge :shh:
Did I bolt you up Will? Sorry if so, I thought you had made an offer?
Now that's an expression I've not heard before - must be one of those Northern things :lol:
Anyway, I'm quite happy with the idea.
Folderol wrote:Now that's an expression I've not heard before - must be one of those Northern things :lol:
Oh! Yes, getting "bolted up" is being volunteered/pressed into a task that you did not want and is not actually in your job descrip'!
Not to be confused with "fitted up" which is something our police never do or ever did.
Post by Dr R »
Folderol wrote:If you really are stuck, send me a priv message - I'm a sucker for an unusual challenge :shh:
In that case I most definitely will, thank you.
Rich
Dr R
This is proving to be a very strange design indeed! I've worked out a drawing, and it's so strange I had to keep re-checking it :o
See here.
(Updated diagram shown above)
Cold checks with a meter suggest there are no faults, so the tone control should work, if there are no dried out caps, although with such low impedances I'm not quite sure how! The unmodified gain of the amplifers is 20, so those 1u feedback caps will behave as if they were about 20u.
Notice that DC supply to the microphones. This makes me think they are electrets
As soon as i can get into the office, I'll snaffle their all-singing cap tester and find out what the actual values are.
The 150n 'dry' caps are a guess based on the amp spec sheet.
The 0u22 ones are actually mis-printed so any dot would be off the edge of the cap. Size-wise they couldn't realistically be 22u, and it wouldn't make sense, bearing in mind the feed caps are only 33u.
All very strange :?
Last edited by Hugh Robjohns on Thu Jun 28, 2018 6:16 pm, edited 3 times in total.
Bravo Folderol.
Posts: 13178 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Is it about a bicycle?
And I agree with you that it's a very strange circuit! :?
Are you sure those 1u caps are not connected between pins 1 and 8 of the LM386?
Absolutely. Pins 1, 7, 8 are as naked as a newborn baby.
Also today I did a few active tests in my {cough}kitchen{cough} workshop, using my signal generator (of DIY amp fame) and a modern true RMS multimeter. At these low frequencies they're pretty good.
I worked with an output level of 1V, which is quite reasonable as a headphone level, and as I'm not sure of the correct source impedance, I used 600ohms, 2.2k and 47k. The result was entirely consistent across all of these, which is something I didn't expect actually.
I can confirm the tone control has no measurable effect at all over the range 40Hz to 4kHz :o
Also, the -3dB point relative to 400Hz is 70Hz, which is way too high for a bass.
I might try tapping caps across those present (particularly those 33u coupling ones) and see what transpires.
I'm not at work tomorrow, but if I'm down that way I might drop in and see if I can borrow the cap tester - I should probably get one myself :roll:
Post by Dr R »
;):clap: Huge thanks to Folderol for taking this on. It's beyond the limit of any electronics I have ever forgotten. Which is the tone pot pair??
I think we've found someone who can measure the microphone impedances as requested in a PM. Will let the forum know the outcome.
Thanks again to everyone!
Rich
Dr R
OK, there is an error in tracing the circuit, and it now makes much more sense :blush:
(Updated image -- HR)
If you click on the link itself, you'll get the corrected drawing. The 1u caps are compensation ones that go from the top of the volume control to the wiper.
This doesn't invalidate any of the actual tests. Also the latest news is that the 0.47u caps are dead, tapping one across them immediately made the tone control work.
The 'dry' cap and the 33u one are effectively forming a 2nd order high pass filter, both of them are dropping a significant voltage at 70Hz. Using an R/C calculator, the 33u one against the volume pot at full volume should give a -3dB point of 4.8Hz! so it looks like those are also dead-ish and the only ones that's supposed to be affecting the roll off should be the 'dry' ones. I only guessed their values, but with the behavior shown and good caps elsewhere I would expect the -3dB point to be nearer 45Hz - much more reasonable.
I'm wondering if the unit has been left somewhere hot for an extended period, or is much older than I thought.
Pretty sure they are going to be electret mics given the DC supply present on the mic lines. All electrets have an active impedance converter-cum-output-driver. So they will have a very low output impedance of the order of 100 Ohms or less.
Posts: 43047 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Aha - the 1uF caps now make FAR more sense Folderol! 8-)
Post by Dr R »
The instrument lives in north Wales - but does travel to South Africa and France for extended periods so heat damage is entirely plausible.
As an aside: Apparently it's great to travel with as it's light and will go in an aircraft overhead locker. The downside is that in its bag it looks like a rifle and airport security get very twitchy :-)
Dr R
Well done that man!
Are you sure those capacitors are not old Tantalums? They promised much but after just a few years generally delivered shorts! I guess a few also went open circuit.
@hugh
The tone control tests suggest that these mics are round about 1k. Even a 600ohm source means the control has less effect. 100ohm would give a -3dB point of 3.4kHz at maximum attenuation.
@Dave
That was my first thought, but they look like standard SM electrolytics, and the codes also suggest that. I'll be replacing the 0u47 ones with multilayer ceramics. They are not much bigger, more stable and much quieter.
I'm a bit concerned about the volume pot wiring, as it will have a frequency component, depending on it's position (as well as what's on the output). Near minimum the LF cutoff will be about 400Hz as only the 10ohm resistor will be relevant against the 33u cap, but at full volume it will be 4.8Hz. This could account of the apparent poor low end. So maybe it should be run as close to max as possible.
And finally a bit of bad news. My sig genny seems to have developed a fault on it's higher ranges and goes unstable when the gain is turned up :cry: and it's only about 45 years old.
I'd write a nasty letter to the manufacturer... only it was me :shh:
