Nowadays reliable budget doesn't necessarily mean skimping on relative quality.
I've just purchased usb Class Compliant Focusrite Clarett 2pre usb (not thunderbolt) mk1, not mk2 Clarett+, £130* with 2years warranty 2nd hand used.
https://drive.google.com/file/d/1XHFvjU ... p=drivesdk
Clarett pre A-D is 118dB, D-A 118dB which is pretty high up in Hugh's converter measurements list.
https://www.soundonsound.com/forum/view ... hp?t=86761
As Hugh says
"I consider anything that scores more than about 118dB as being in the territory of top-notch mastering quality equipment."
"Remember, though, that the AES17 measurement is only one aspect of a converter's or interface's performance, and I would caution against using it as the sole means of making purchase decisions... but it does provide a reliable qualitative comparison between devices, and that might be useful."
I can hear a difference in the mic pres compared to my cheaper audio interfaces : lower noise in Clarett mic ins EIN -129dB. Also specs wise the Clarett mic ins have more dynamic range although I haven't had an occasion to test this.
Important to me is Headphone out as I nearly always record, shape sounds, mix on headphones.
Clarett headphone out I can hear clarity more, separation better, increased accuracy in shaping sounds compared to my cheaper audio interfaces from budget range of Line6, M-Audio, Presonus, Zoom, their budget range headphone out also have a grittyness hurts my ears after a short while.
Clarett 2pre usb isn't standalone, although it is usb Class Compliant works with my 2018 ipad pro usbC port.
Clarett powered from a usb battery power bank that has 12V 1.5A out as this Romoss 30000mAh (approx 25000mAh in use) with a set of universal USB to DC in adapter plugs with the usb cable rated to 12V.
There's better Romoss version outputs : 20V 1.5A/ 15V 2A / 12V 2.5A.
There's even better usb battery power banks 65W outputs : 20V 3.25A/ 15V 3A/ 12 3A.
Have to set up Clarett in mac or wind focusrite control panel thereafter ready to use on ipad pro usbC port.
https://support.focusrite.com/hc/en-gb/ ... -iPad-Pro-
I returned fortnight earlier my repurchased Focusrite Forte which I previously had approx 6months after reading Hugh's converter list and SoS review : Forte 117dB A-D , 118dB D-A.
Even though Forte is same quality as Clarett 2pre, even though Clarett is based upon Forte, because Forte isn't, Clarett 2pre is usb Class Compliant.
This is just for me to think this way. Nobody else.
*£130 would feed 2 small families one month in this cost of living crisis.
£130 is more than the annual salary of millions of folk around the World.
