Arpangel wrote: ↑Sat Jun 25, 2022 12:10 pm
OK so it doesn’t give me extra hardware inputs just more choice of inputs from the ones already on board?
The hardware inputs are on the S16.
I’ll try and break it down- think of it like this:
*All and any X32 is a 32 channel mixer. They all have exactly the same ‘brain’ and processing power, but but only the big ones have the physical connections for the 32 input.
*In order to have physical inputs for all channels on the smaller X32 (Compact etc) you need to connect it to a stagebox like the S16. That gives you 16 extra physical inputs and 8 outputs
in addition to the connections already on the desk. For example, you can assign the desk inputs to channels 1-16 and the S16 inputs to 17-32.
*Obviously, the Compact has less faders than the big X32, so you need to use the fader layers to access the channels (there are buttons on the desk to switch labels, clearly labelled such as ‘1-8’, ‘9-16’ etc.
*So, essentially, an X32 Compact with an S16 offers the same power and connections as the big X32, just that half the connections are moved out of way onto the S16, and you need to press a button on the X32 a bit more often.
